self compiling: 'Goto_Rules_Root' was not declared
megamarco83
#1 Post by megamarco83 » 05 Dec 2018, 01:29
Hi, i download two plugin from playground
i added them on src folder and renamed it as ESPEasy
now i want to compile, so i change on global.sh, setting the DEV and comment the NORMAL
i not able / understand how use platformio, so i continue to use arduino IDE that on november nightly espeasy was working good
now i try to create the bin file with arduino ide 1.8.7 (last version) copy the libraries inside arduino folder and run the compiling.
i receive this error:
exit status 1
'Goto_Rules_Root' was not declared in this scope
what i can do to solve this issue?
it seams that there is an error inside the code? is it possible?
thanks
Re: self compiling: 'Goto_Rules_Root' was not declared
#2 Post by grovkillen » 05 Dec 2018, 06:56
You renamed the "src" folder to "ESPEasy"? That is not what you should do.
megamarco83
#3 Post by megamarco83 » 05 Dec 2018, 19:01
grovkillen wrote: 05 Dec 2018, 06:56 You renamed the "src" folder to "ESPEasy"? That is not what you should do.
ehm....why not?
on the previous version it was needed....and if i'm not wrong also arduino IDE require that ESPEasy.ino should be contained in a folder that has its name: "ESPEasy"
what name i should give to the folder "src" ?
thanks Grovkillen, your help is every time appreciate and usefull :)
#4 Post by grovkillen » 05 Dec 2018, 20:11
Ok, I must have missed that part of Arduino IDE. We're using PlatformIO as our official IDE.
megamarco83
#5 Post by megamarco83 » 05 Dec 2018, 20:29
grovkillen wrote: 05 Dec 2018, 20:11 Ok, I must have missed that part of Arduino IDE. We're using PlatformIO as our official IDE.
Yes i know.. And i download it but still unable to use it... Can you help me?
#6 Post by grovkillen » 05 Dec 2018, 20:30
Did you read the wiki on setting up the PlatformIO environment?
megamarco83
#7 Post by megamarco83 » 05 Dec 2018, 20:46
grovkillen wrote: 05 Dec 2018, 20:30 Did you read the wiki on setting up the PlatformIO environment?
i read the wiki but related to arduino IDE...
https://www.letscontrolit.com/wiki/inde ... are_Upload
waspie
#8 Post by waspie » 05 Dec 2018, 21:18
I self compile fairly regularly and I use 1.8.7 and I haven't had any troubles. I think I did one a couple days ago without issue...
megamarco83
#9 Post by megamarco83 » 05 Dec 2018, 21:24
waspie wrote: 05 Dec 2018, 21:18 I self compile fairly regularly and I use 1.8.7 and I haven't had any troubles. I think I did one a couple days ago without issue...
can you please try with last release?
i try one month ago or a bit later without any problems...but with last release i find this error :(
i copy paste the library inside arduino folder, and sice that i find this error..i do not know it is linked
waspie
#10 Post by waspie » 05 Dec 2018, 21:32
megamarco83 wrote: 05 Dec 2018, 21:24
i will try tonight about 4-5 hours from now
megamarco83
#11 Post by megamarco83 » 05 Dec 2018, 22:44
waspie wrote: 05 Dec 2018, 21:32
thanks, i compile right now a version ESPEasy_mega-20181128
and works perfectly
i try to compile the last version: ESPEasy_mega-20181204
but i receive the error:
C:\Users\Marco\Desktop\2222\source\ESPEasy\WebServer.ino: In function 'void WebServerInit()':
WebServer:519:30: error: 'Goto_Rules_Root' was not declared in this scope
   WebServer.on(F("/rules/"), Goto_Rules_Root);
WebServer:525:36: error: 'handle_rules_delete' was not declared in this scope
   WebServer.on(F("/rules/delete"), handle_rules_delete);
   exit status 1
#12 Post by grovkillen » 05 Dec 2018, 22:52
megamarco83 wrote: 05 Dec 2018, 20:46
https://www.letscontrolit.com/wiki/inde ... platformio
megamarco83
#13 Post by megamarco83 » 05 Dec 2018, 23:03
grovkillen wrote: 05 Dec 2018, 22:52
thanks, i red also this one, installing platformio successfull and open the project using folder where is placed .ini file, but i do not succed on compiling.
if i press F7 nothing is apparing...
and i'm not able to complile
using arduino ide:
since the version of 20181128 is ok, using last version 20181204 i receve the error that i reported in previous message
Domosapiens
#14 Post by Domosapiens » 05 Dec 2018, 23:23
megamarco83
#15 Post by megamarco83 » 06 Dec 2018, 00:32
Domosapiens wrote: 05 Dec 2018, 23:23 Also seen here:
https://github.com/letscontrolit/ESPEas ... t-31532972
Hope this helps
yes! it helps so much my friend!
i simply delete the /* arguments */ that are present in three rows and substitue with ()
they are in Web Interface rules page
now the compiling is doing good
if you can remove from the code, it will be perfect also for arduino processing, thanks!
waspie
#16 Post by waspie » 06 Dec 2018, 03:45
here's the error i'm seeing:
WebServer_Rules:256:25: error: 'Goto_Rules_Root' was not declared in this scope
Goto_Rules_Root();
Users browsing this forum: No registered users and 34 guests
