WHY the data of MHZ19B 200ppm less than Senseair s8 0053
halli
#1 Post by halli » 14 Dec 2018, 03:29
hello,everyone,I am a freshman of EASYESP.
I buy MHZ19B and Senseair s8 0053,connet them to two ESP8266 nodemcu,which firmware is ESP_Easy_mega-20181125_normal_ESP8266_4096.bin
Disable the ABC for MHZ19B, and calibration it manually(Reference to official documents)。
But the data from the two sensor is Big difference,please see the attachment png。
I test serval days ,the result is the same, WHY? which one is Inaccurate? how to finger out ?
Re: WHY the data of MHZ19B 200ppm less than Senseair s8 0053
#2 Post by grovkillen » 14 Dec 2018, 06:12
How long have they been running? The ABC inside the S8 is 8 days but it will not do a 200ppm adjustment in one period, it probably need two cycles. But if the S8 has been running for 3 weeks or more I'd say that the S8 is the correct one.
PS. I work at Senseair (2 days a week) and if you PM me the serial number of the S8 I could see what calibration had been done at factory. If the sensor is miss-behaving I could hook you up with a test sensor for further reference.
halli
#3 Post by halli » 17 Dec 2018, 04:30
Thx,my s8 just run about one week,so,I will continue monitoring it for a while.
but i am sure that s8 is not correct,because I put it in Outdoor environment for a while ,it's Minimum readings is 460PPM,I think it should be about 400ppm
#4 Post by grovkillen » 17 Dec 2018, 06:07
Then I'd suspect there ABC will take care of the S8. But if the S8 is reporting 460 ppm for the outdoors I would suspect the MH-Z19 be incorrect also? I.e. measuring too low?
rickitaly
#5 Post by rickitaly » 01 Dec 2019, 12:23
Hello, i just purchased a Senseair S8 and connected to Wemos D1 mini to give me CO2 data with ESPEasy.
First of all i put it outside to check proper values, and here is what i get:
How can it be correct? Never less than 500!
Please do not consider the spike, i rebooted and tried to change the Wemos to another one.
#6 Post by grovkillen » 01 Dec 2019, 12:57
Did you buy it from me?
#7 Post by TD-er » 01 Dec 2019, 13:22
grovkillen wrote: 01 Dec 2019, 12:57 Did you buy it from me?
Made a typo in your (re)calibration lab? ;)
#8 Post by grovkillen » 01 Dec 2019, 18:06
I hope not! :o
Users browsing this forum: No registered users and 26 guests
