[noob question] esp8266 rules + analog read mq-2 senor
pdrobek
#1 Post by pdrobek » 27 Dec 2018, 21:46
Hi folks
Near 4 days ago i switched to espeasy from my own firmware for wemos d1 mini pro(esp8266).I read whole wiki page for rules which could be set on espeasy and still something work wrong in my opinion.
Please see where i am doing wrong things
I create device Analog input internal named it mq2 with values named value. In short mq2#value
I also create rule(s) to switch on/off relay connected to GPIO5
on [mq2]#value>75 do
gpio,5,1
on [mq2]#value<=75 do
gpio,5,0
In log i see
1125701: ADC : Analog value: 63
1125704: EVENT: mq2#value=63.00
1125721: Domoticz: Sensortype: 1 idx: 64 values: 63
As far i observe my relay it wont switch on even if mq2#value is greater than 100
Please tell how to create rule to frequently check for analog value and power on/off relay
dynamicdave
Re: [noob question] esp8266 rules + analog read mq-2 senor
#2 Post by dynamicdave » 27 Dec 2018, 22:11
You could try this piece of code.
It checks the value of mq2 every 2 seconds (adjust the timing to suit your needs).
On System#Boot do
  GPIO,5,0
  timerSet,1,2  //Set timer1 for 2 seconds (adjust the timing to suit your needs)
on Rules#Timer=1 do    //This is executed when timer1 runs out
  if [mq2#value]>75
    GPIO,5,1
    GPIO,5,0
  timerSet,1,2  // set timer1 for another 2 seconds
pdrobek
[Solved][noob question] esp8266 rules + analog read mq-2 senor
#3 Post by pdrobek » 27 Dec 2018, 22:26
It works!
So i have to read another wiki for timers :-)
dynamicdave
#4 Post by dynamicdave » 28 Dec 2018, 10:25
Glad to help.
Cheers from david
