How to convert Celsius to Fahrenheit in ESP Easy
andy
#1 Post by andy » 26 Jan 2016, 23:48
ESP Easy displays the DS18b20 output in Celsius, but I'd like to change the output to Fahrenheit. I've tried setting the formula to
%value% * 9 / 5 + 32
but my 24.63° turns into 25.44°. In fact, after wiping out the formula the display changes to 24.06°, so I'm not sure the code had any effect. Also, after I submit the '+' symbol disappears replaced with a couple empty spaces - the formula now shows
%value% * 9 / 5   32
Clearly I'm doing something wrong, but I can't find any documentation on how these formulas should be formatted. Anybody have some pointers?
costo
Re: How to convert Celsius to Fahrenheit in ESP Easy
#2 Post by costo » 27 Jan 2016, 00:20
Which version do you use at the moment ?
I remember the '+' symbol disappeared in an older version, think it was the stable version R48.
If so than the solution is to upgrade, preferable to R772.
edit: I mean R72 ofcourse
andy
#3 Post by andy » 27 Jan 2016, 00:31
Yes, I'm using R048. I'll look for R72 and see how that works - thanks!
Erm - where would I find R72?
costo
#4 Post by costo » 27 Jan 2016, 00:47
here https://github.com/ESP8266nu/ you find the updated beta-versions.
You can find this information on http://www.esp8266.nu/index.php/Main_Page at the bottom of the page.
R72 seems to be pretty stable and has all the latest features.
andy
#5 Post by andy » 27 Jan 2016, 23:03
Okay, I've got R072 loaded and running. Still not seeing any change in temperature readings.
Here is the settings I have:
Device: Temperature - DS18b20
Name:
IDX / Var: 120
1st GPIO: GPIO-14
Device Nr: 1 ROM: 28-3b-3e-2a-7-0-0-3c
Send Data: checked
Formula Temperature: Doesn't seem to matter what is in here
Value Name 1: Temperature
The readings change when I warm or cool the thermometer, but I cannot seem to get the formula to have any effect.
Also, what is the significance of IDX / Var? It appears to want some number in there, but I can't tell what it means.
andy
#6 Post by andy » 27 Jan 2016, 23:52
Ha! Figured it out.
[HINT] DO NOT USE SPACES IN YOUR FORMULA [/HINT]
%value%*9/5+32
Works a treat!
MarkIngle
#7 Post by MarkIngle » 03 Mar 2016, 04:33
Would you mind sharing some details on your setup? I have a ESP12E Dev board and I am trying to do the same thing with a temp sensor. Currently I am not getting any readings from the sensor...only zeros! One thing that is strange is that I don't have any options for ROM..the drop down list is zero. Also I am using a temp sensor that came with an Arduino kit...I am assuming it will work. Any help would be much appreciated.
tozett
#8 Post by tozett » 03 Mar 2016, 08:22
i had the same observation where the ROM stayed empty.
i was missing a pullup resistor.
for the 1wire setup the wiki states:
It only needs a 4k7 resistor connected between VCC and the GPIO datapin.
see (with images):
http://www.esp8266.nu/index.php/TemperatureSensor
BUT i think, the original topic seemed SOLVED.... ;)
