%eventvalue% does not give value
Soundstorm
#1 Post by Soundstorm » 26 Jan 2019, 17:27
Hi guys
I'm trying to transfer a value through an HTTP event, but I can't seem to get it working. Went back to a clean install just to make sure I did nothing wrong, but still the same issue.
Just using the rule from the example, I get the following:
 on remoteTimerControl do
   timerSet,1,%eventvalue%
http://192.168.1.82/control?cmd=event,remoteTimerControl=5
705880 : EVENT: remoteTimerControl=5
705883 : ACT : timerSet,1,%eventvalue%
706337 : EVENT: Rules#Timer=1
Why isn't the 5 transferred to the Timer?
Im running build 120
Build:	120
Core Version:	2_3_0
Hardware is a Wemos D1 Mini
How can I get this working?
Re: %eventvalue% does not give value
#2 Post by grovkillen » 26 Jan 2019, 17:51
I'm not sure that the event value is available in that old version.
Soundstorm
#3 Post by Soundstorm » 26 Jan 2019, 17:54
I don't mind using a newer version if that is the issue, but I can't seem to find a version that works.
#4 Post by grovkillen » 26 Jan 2019, 17:56
Soundstorm
#5 Post by Soundstorm » 26 Jan 2019, 18:13
Yes, tried a couple of them (did a full erase in between). Don't start as AP, so I can't configure them.
LED stays on most of the time.
#6 Post by grovkillen » 26 Jan 2019, 19:50
What type of unit are you flashing?
Soundstorm
#7 Post by Soundstorm » 27 Jan 2019, 09:45
Got it working with mega-20190116 and the espeasyflasher instead of the espresif one.
%eventvalue% works now!
Thanks for pointing out it was a version related issue! Just a bit strange this is not mentioned in the documentation, as Build 120 is the latest stable version according to it.
Cheers
#8 Post by grovkillen » 27 Jan 2019, 11:48
Soundstorm wrote: 27 Jan 2019, 09:45 Got it working with mega-20190116 and the espeasyflasher instead of the espresif one.
Cheers
I know, it's the current/official stable version. But we are releasing the brand new version soon. But we're doing a lot of development in the background that we want to have in place for the release. I'm the one responsible for the documentation but haven't had time for a couple of weeks (I'm doing consulting for an income until this brings us a steady income)
Soundstorm
#9 Post by Soundstorm » 27 Jan 2019, 13:15
No problem. Just a bit confusing when you just start out with espeasy, and the first thing you try doesn't work.
Thanks a lot. Keep up to good work!
Users browsing this forum: Ahrefs [Bot] and 29 guests
