Unsupported or incorrectly supported devices
Stuntteam
Site Beheer
#1 Post by Stuntteam » 27 Jan 2016, 20:21
If you have a device that is not yet supported you can do the following to help us.
Launch RFlink Loader (or any terminal program)
Just select the correct serial port to which your Arduino/RFLink is connected and press the [Serial Port Logging] button.
Then also press the button [Log Mode: Debug] The program will then start logging the special RF pulse packets that we need to analyze. It will then start logging.
Once the program is logging, either wait for packets to show (in case of remote sensors that periodically send data, like outdoor temperature sensors) or press buttons on your remote or on the device.
(For terminal programs, select serial port with settings: 57600/n/8/1)
See here for more info:
http://www.nemcon.nl/blog2/2015/07/cc
Once you have log data, send it to frankzirrone@gmail.com or post it here on the forum.
