And am trying to use it as pulse counter for my energy counter.
I connected it do GPIO0 bot its not counting at all.
I foundout that this module giving high level on standby and low on pulse. Its ok for Espeasy (R147)?
Then it should be easy to do.
Hi. To get a reading from the pulse counter in Domoticz . Go back to your esp and change you formula to "%value%*60". The pulse counter resets its value every minute so this gives you the most accurate values.journeyman wrote: ↑04 Mar 2017, 17:32 Its working now on another ESP, giving some numbers but the only problem left its to set it correctly in domoticz its giving only 30 - 40watts and no kWh counting.
Thank you!
Here's my 1 year old config that is still running. You may use it as inspiration: https://testoftimes.com/2017/11/25/moni ... g-esp8266/Naesstrom wrote: ↑03 Nov 2018, 14:29 I'm planning on attaching a ESP to my S0 interface to and the connections seems clear... but could anyone share some info on what rules/calculations to use based on the imp/kwh on the reader? How often should the ESP send the value etc?
I'm not using domoticz but home-assistant so I don't have your nifty premade configs!![]()
Sweet thanks, I can't see a difference between kWh and kWh (time)?grovkillen wrote: ↑03 Nov 2018, 17:07 Here's my 1 year old config that is still running. You may use it as inspiration: https://testoftimes.com/2017/11/25/moni ... g-esp8266/
