ask for help Where do I enter the Blynk token so I can connect to the blynk server?
leachimtrebron
Token from Blynk where to enter = ???
Re: Token from Blynk where to enter = ???
Aren't it in the controller settings for Blynk?
I tried using blink, it worked.
But blynk says that the device is offline (disconnect), it can be removed in a blynk , but then I don't know when esp8266 off or on. It's not very convenient.
I installed platformio and added it to asp easy.info (#include <BlynkSimpleEsp8266.h>, char auth [], Blink.config (auth);,Blink.run ();). It worked, I got the device online.
Maybe there is an easier way to send status to Blynk?
Open an issue on GitHub please.
