[SOLVED]ESP-07 Problem
Snyp54
#1 Post by Snyp54 » 31 Jan 2016, 10:31
Hello everybody.
I'm french user of ESPEASY and is very cool software for domoticz.
I run ESPEASY on two ESP-01 with one have DHT22 and Other one have BMP180.
My problem it's with ESP-07.When i upload the sketch it's work fine but, when i go in ESP-07 for enter SSID and PASS and I valid,the esp-07 don't connect to my network.
Do you have the same problem? Thanks for future help.
Regards ;)
costo
Re: ESP-07 Problem
#2 Post by costo » 31 Jan 2016, 10:58
You need to give more information about the esp-07 setup.
Like what version of espeasy you use, which settings in the Arduino IDE you use to flash the esp…
What device(s) are connected .
What do you see in the IDE when you monitor the ESP.
Snyp54
Re: ESP-07 Problem
#3 Post by Snyp54 » 31 Jan 2016, 13:36
Oops sorry :).
I use arduino 1.6.5-r5
Board ESP8266 v2.0.0
Flash mode: QIO
Flash Frequency: 80mhz
Uplod using serial
Flash size: 1M (64 SPIFFS)
Reset method: CK
UIpload speed: 115200
No device connected for the moment
ESPEASY R048
costo
Re: ESP-07 Problem
#4 Post by costo » 31 Jan 2016, 14:26
You use the 'stable' R48 release. It is from some time ago and it has some known and very likely also some unknown bugs.
I advice you to go to www.esp8266.nu scroll to the end of that page and click the github link where you find the latest beta. It is R75 at the moment. Flash that version into your esp-07 and see what happens. It has a field where it displays the flaash-size of the esp, so you can check if it really has 1 MB.
Snyp54
Re: ESP-07 Problem
#5 Post by Snyp54 » 31 Jan 2016, 16:32
Thank you i try tonight ;)
Snyp54
Re: ESP-07 Problem
#6 Post by Snyp54 » 04 Feb 2016, 18:53
costo wrote:You use the 'stable' R48 release. It is from some time ago and it has some known and very likely also some unknown bugs.
I advice you to go to http://www.esp8266.nu scroll to the end of that page and click the github link where you find the latest beta. It is R75 at the moment. Flash that version into your esp-07 and see what happens. It has a field where it displays the flaash-size of the esp, so you can check if it really has 1 MB.
Hi it's work fine now but i can't find the field where it display.
Users browsing this forum: Semrush [Bot] and 11 guests
