No I2C with Sonoff 4CH R2
ajheyworth
#1 Post by ajheyworth » 20 Apr 2019, 09:06
Just diving into a Sonoff 4CH R2 which provides 4x relay outputs, a couple of unused GPIO pins on the board and 4x inputs tied to buttons.
I want to add an MCP23017 port expander to gain some more useful IO on the side and also for an OLED screen.
Q1. Trawling the internet it would seem that GPIO 01 and GPIO 03 are used for I2C. Does anyone else concur?
Q2. In ESP Easy Mega software, it seems that GPIO 01 and GPIO 03 are greyed out, so can't be allocated for I2C, yet I cannot see them allocated anywhere else.
Whilst on this topic...
Q3. Has anyone come across a very cheap IO breakout board tied to a port expander/circuit - just to provide a combination of both input and output connections? I've seen the relay boards, but am specifically looking for more inputs to reed switches etc.
Many thanks
papperone
Re: No I2C with Sonoff 4CH R2
#2 Post by papperone » 21 Apr 2019, 08:19
ajheyworth wrote: 20 Apr 2019, 09:06 Q1. Trawling the internet it would seem that GPIO 01 and GPIO 03 are used for I2C. Does anyone else concur?
As far as I know the standard I2C pins are GPIO4 and GPIO5 and I use them in quite few projects....
ajheyworth
#3 Post by ajheyworth » 21 Apr 2019, 08:27
papperone wrote: 21 Apr 2019, 08:19
Here is the known GPIO list for the Sonoff 4CH R2:
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
papperone
#4 Post by papperone » 03 May 2019, 07:10
ajheyworth wrote: 21 Apr 2019, 08:27 Here is the known GPIO list for the Sonoff 4CH R2:
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
Then there are chances you can't use I2C with yout sonoff 4CH Pro due to the fact you have no good GPIO avail for the protocol.
I can confirm GPIO1/3 are the hardware serial and probably can't be used reliably for I2C communication.
toffel969
#5 Post by toffel969 » 03 May 2019, 11:48
papperone wrote: 03 May 2019, 07:10
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
You can use GPIO1/3 as I2C after disabling serial in advanced tab.
Schmurtz
#6 Post by Schmurtz » 25 Oct 2020, 11:35
I am interested in the outcome of this question!
So is it finally possible to add an MCP23017 to the Sonoff 4CH R2 using I²C ?
Once serial RX/TX disabled you can use GPIO 1 and 3 for I²C ?
Someone has done it successfully ?
#7 Post by TD-er » 25 Oct 2020, 13:07
It should indeed be possible to use those pins for I2C.
Just make sure to uncheck "Enable Serial port:" on the Tools->Advanced tab.
I do advice to use a simple pin header for this, as you may need to use them later for serial again to upgrade ESPEasy as this one uses only an 1M flash chip.
#8 Post by Ath » 25 Oct 2020, 13:29
Schmurtz wrote: 25 Oct 2020, 11:35 Someone has done it successfully ?
I have several Sonoff S20's, that like the 4CH R2 only expose gpio 1 and 3, to connect I2C sensors, though you must take care of the fact that there may be dangerously high voltages on these connections, so please wire them safely!
