ESPEasy WiFi reconnect Rules
Rob Muller
#1 Post by Rob Muller » 08 Apr 2019, 13:11
Friends,
After a recent router failure i experienced that ESPEasy would not reconnect to WiFi on its own. A device reboot was required.
All my devices run a stable version of ESPEasy Mega-......
I could not find a script to monitor WiFi without use of plugins not available in the basic stable version, and i try to stay off the {b}leeding edge...
So i cobbled this together, i tested this on many versions and it worked for all Mega....
on System#Boot do
    Let,1,0                              // set user variable to initial state of 0
EndOn
on Wifi#Disconnected do              	 // if no wifi, wait 3 minutes
  if [VAR#1]=0
    timerSet,1,180
    Let,1,1                              // set user variable 1 to 1 to prevent re-set of var1 on each event.
on Wifi#Connected do     	 	 // if wifi returns, cancel reboot
  timerSet,1,0                    	 // cancel timer
  Let,1,0                                // set user variable 1 to 0
On Rules#Timer=1 do                    	 // if still no Wifi, reboot
  reboot
I hope others will find a use for this.
If you have improvements or a beter idea, share please
Regards,
Rob
Thanks for reading,
regards,
Rob
riker1
Re: ESPEasy WiFi reconnect Rules
#2 Post by riker1 » 08 Apr 2019, 14:25
thanks
Was wondering is a
wificonnect
would solve it ,
doing a reboot is more save?
Rob Muller
#3 Post by Rob Muller » 08 Apr 2019, 19:17
Riker1,
I tried that and could not get it to work reliably, but a reboot worked 100% of the time.
maybe a reboot clears something in memory that prevents re-connection.
I tested using the following method, as i have only one wifi network and cannot switch that off if i want to live (Wife!!)
Testing method:
connect to iPhone personal hotspot
open serial connection
switch off personal hotspot and observe reconnect in serial console
thanks for your reaction
Rob
Thanks for reading,
regards,
Rob
riker1
#4 Post by riker1 » 09 Apr 2019, 07:53
thanks Rob
1CM69
#5 Post by 1CM69 » 09 Apr 2019, 13:29
Rob Muller wrote: 08 Apr 2019, 13:11 Friends,
on System#Boot do
EndOn
  if [VAR#1]=0
    timerSet,1,180
  reboot
Regards,
Rob
Nice, thanks
hoeby
#6 Post by hoeby » 04 Aug 2019, 21:21
Would like to use the script, but have some question about it
The script uses
VAR#1
Do i need to make a dummy device (or something else) to store the value.
Or is VAR a default function in espeasy?
#7 Post by ThomasB » 04 Aug 2019, 22:05
VARs (VAR#1 - VAR#16, alias %v1% - %v16%) are Custom Variables that are separate from those used in the dummy plugin. They are built-in/default, so a plugin is not needed to use them. Some details:
viewtopic.php?t=6288
Useful Things to know:
- Unlike Dummy plugin defined variables, the %v% variables are lost (reset to zero) on a warm reboot. So choose a Dummy for values that must survive ESPEz's pandemic random reboots.
- For debugging, you can see the values of all the %v% on the Tools=>SystemVariables page.
mpolet
#8 Post by mpolet » 01 Dec 2019, 08:51
Had exactly the same; the wemos itself was alive for 8 days but not connecting to my AP. The 'configesp' AP was visible from my laptop though. After rebooting it (via that configesp) it was connecting to my AP again.
I now implemented your script in it, see how it will perform now.
#9 Post by TD-er » 01 Dec 2019, 13:19
Maybe also use a more recent build.
A few weeks ago I addressed some logic issues in when to reconnect, when to start the AP etc.
Rob Muller
#10 Post by Rob Muller » 04 Jan 2020, 18:57
@TDer
i run ESPEasy mostly on sonoff Basics, with 1M Memory.
Upgrading those via OTA using the two step process has been less than successful for me, requiring me to dig them up and reflash them manually.
So i decided to pick a somewhat stable release and stick with that, and dealing with he issues that i encounter. The power failure issue was the only major one, prompting me to publish the solution i crafted.
thanks for investing your time into ESPEasy
Thanks for reading,
regards,
Rob
#11 Post by TD-er » 05 Jan 2020, 01:29
One of the more recent newly added features in the core lib is to allow to flash compressed images.
I have not yet tested it myself, but my hope is that it will make 1M updates less difficult.
So let's hope it will indeed be easier to perform OTA updates in the future.
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 15 guests
