check if Sensor is active
ingoiot
#1 Post by ingoiot » 20 Oct 2019, 00:43
i tried this code to check if a sensor gives plausible values
if its out of the range of 10 to 100 degrees(because of a broken cable e.g.)
it should turn off the relay.
but it doesnt work.
it prevents from turning on as the value NaN is never valid for 10 to 100 i think,
but it doesnt turn it off.
on Rules#Timer=1 do
 if [DS18b20#Temperature]<10 or [DS18b20#Temperature]>100
   sendTo 1,event,RelayOff
 if [DS18b20#Temperature]<[DummyVar#tempSetpoint]
   sendTo 1,event,RelayOn
 if [DS18b20#Temperature]>[DummyVar#tempSetpoint]
Re: check if Sensor is active
#2 Post by TD-er » 20 Oct 2019, 10:33
You could turn it on at the boot event?
NaN compared to any value is always false.
ingoiot
#3 Post by ingoiot » 20 Oct 2019, 12:00
the boot event occurs only once? so it only checked on boottime if a sensor is present?
i think im using if/else wrong
timer 1 never expires (ist set in another rule, but i think that doesnt mater)
so normally the whole rule should be skipped.
edit:my wrong timer 1 is alway on so it should run only once
but this part works
ingoiot
#4 Post by ingoiot » 20 Oct 2019, 12:24
i just tried
on [DS18b20#Temperature]>10 or [DS18b20#Temperature]<100 do
but seems also to be no valid code.
#5 Post by grovkillen » 20 Oct 2019, 13:32
on [DS18b20#Temperature] do
 If  [DS18b20#Temperature]>10 or [DS18b20#Temperature]<100
   Event,SetTemp
 EndIf
EndOn
On SetTemp Do
  EndIf
EndOn
ingoiot
#6 Post by ingoiot » 20 Oct 2019, 14:05
the termperature event shows up as:
EVENT: ds18b20#Temperature=15.50
but the SetTemp event never shows up in the log,
even this rule:
on [ds18b20#Temperature] do
   Event,SetTemp
 EndIf
EndOn
On SetTemp do
 if [ds18b20#Temperature]<[DummyVar#tempSetpoint]
  EndIf
EndOn
generates no settemp event.
(everything in espeasy is not case senstitive, am i right?)
#7 Post by grovkillen » 20 Oct 2019, 14:29
What version do you use?
ingoiot
#8 Post by ingoiot » 20 Oct 2019, 14:33
mega-20190809
whats the difference between old and new ruletype?
Domosapiens
#9 Post by Domosapiens » 20 Oct 2019, 16:59
In this part ...no EndIf !
   Event,SetTemp
 EndIf
EndOn
ingoiot
#10 Post by ingoiot » 20 Oct 2019, 17:27
now it looks like this, but still no settemp event
   event,SetTemp
EndOn
On SetTemp do
  EndIf
EndOn
Domosapiens
#11 Post by Domosapiens » 20 Oct 2019, 18:13
   event,SetTemp
EndOn
Must be:
on ds18b20#Temperature do
   event,SetTemp
EndOn
you are not operating on the content ( conent is with []), but on the event that ds18b20#Temperature is updated , so no [] there
ingoiot
#12 Post by ingoiot » 20 Oct 2019, 18:53
works much better:) tnx
looks like everything is working right now, except
that the first else part is not executed.
i switched the ds18b29 error from NaN to 0, but that didnt help.
the SetTempEvent isnt called in the logs, that looks ok, but
the else statment isnt run.
on DS18b20#Temperature do
 If  [DS18b20#Temperature]>10 and [DS18b20#Temperature]<100
   Event,SetTempEvent
else   //doesnt execute
 EndIf
EndOn
On SetTempEvent Do
  EndIf
EndOn
#13 Post by grovkillen » 20 Oct 2019, 19:04
"and" means that both need to be true...
#14 Post by grovkillen » 20 Oct 2019, 19:05
Domosapiens wrote: 20 Oct 2019, 18:13
   event,SetTemp
EndOn
Must be:
   event,SetTemp
EndOn
Darn! How did I miss that! :P
ingoiot
#15 Post by ingoiot » 20 Oct 2019, 19:23
thats what i want. the event should be only true as long as the temperatue is between 10 and 100 degrees
so when the sensor fails it shuts off.
#16 Post by grovkillen » 20 Oct 2019, 19:32
Yes but are the temperature below 10 or above 100 now when you're trying the rule?
ingoiot
#17 Post by ingoiot » 20 Oct 2019, 19:58
the temp is about 16 degrees.
i pull out the sensor so the value should become 0,
(and it shows 0 in device menu)
therefore it should send relayoff
#18 Post by TD-er » 20 Oct 2019, 21:03
Hmm nope, if the sensor cannot be read, the plugin should not send out a success = true when performing the PLUGIN_READ function.
Meaning the sensor will not trigger an event.
As was also opted as a new feature, we should send out an error event when the sensor cannot be read.
But it is not there yet.
ingoiot
#19 Post by ingoiot » 20 Oct 2019, 22:12
tnx,
so i changed my stayalive rule to
  sendTo 1,event,StayAlive
this should send the stayalive function with interval set for the sensor i think.
and if the senor has an error it shouldnt run - seem to work for now
