Somfy Exavia 500 pair with rflink
About receivers, transmitters, transceivers, connections, antennas etc.
racoonx2p
#1 Post by racoonx2p » 27 Oct 2019, 18:47
I'm using Robotdyn ATmega2560+ESP8266 and RFlink for Somfy devices. I've set it up for my two blinds and it's working as expected. Now I bought Somfy Exavia 500 (Automatic gate opening) but I'm unable to find out how to do pairing with this motor. There are two keypop 2 controlers attached. Pairing is done as on the picture bellow:
Manual for Exavia
I can see output in log when I press buttons on remote controllers in RFLinkLoader:
20;11;Debug;RTS P3;a4f50043bbb549cc0033;
20;12;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;13;Debug;RTS P1;a4f20044bbb549c40019;
20;14;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;15;Debug;RTS P2;a4f20044bbb549c80026;
20;16;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;17;Debug;RTS P3;a4f20044bbb549cc0033;
20;18;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;19;Debug;RTS P1;a4f00046bbb549c40019;
20;1A;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;1B;Debug;RTS P2;a4f00046bbb549c80026;
20;1C;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;1D;Debug;RTS P3;a4f00046bbb549cc0033;
20;1E;RTS;ID=2bbb549;SWITCH=01;CMD=STOP;
20;1F;Debug;RTS P1;a4f50143bab549c40019;
20;20;RTS;ID=2bab549;SWITCH=01;CMD=STOP;
When I tried to pair it the same way as blinds I got OK answer:
10;RTS;555555;0417;9;PAIR;
20;C6;OK;
But when I send command from RFLinkLoder nothing happens. I think problem is that I'm unable to set motor to programming mode and pair RFlink with it.
Any help will/would be appreciated.
Errance
Re: Somfy Exavia 500 pair with rflink
#2 Post by Errance » 20 Nov 2019, 14:13
I have an Exavia 500 & it's works with Rflink. You need to put the Rflink like the remote control, just in front of the control electronic and send a pair signal. It's a rolling code. Do you speech french ? I've done what you want to do with the help of these websites :
https://www.homentic.fr/rflink-appairer ... ns-jeedom/
https://matdomotique.wordpress.com/2016 ... -et-somfy/
sankukai8
#3 Post by sankukai8 » 22 Nov 2019, 16:10
bonjour,
Vous posez le rflink sur la cible ou près de la cible? Est ce l'antenne qui compte?
Que capte en fait cette cible?
Chez moi, lorsque j'envoie une commande pair, rien ne se passe...
Que faut il envoyer ensuite?
Errance
#4 Post by Errance » 23 Nov 2019, 15:32
C'est l'antenne qui compte, mais il faut bien que ça clignote, c'est un peu galère & j'ai passé un peu de temps à réussir.
sankukai8
#5 Post by sankukai8 » 26 Nov 2019, 08:41
Merci pour la réponse. Je teste ça dès que possible
racoonx2p
#6 Post by racoonx2p » 09 Dec 2019, 14:51
Hey,
thanks for reply. I don't speak french unfortunately but google translate is good friend of mine ;) .
I know both URLs you shared. My problem is that I'm not sure how to put Exavia to pairing mode :?: . When I try it just like that without anything, I got OK reply but it's not working anyway..
My steps are:
1. Capture opening with my remote
20;06;RTS;ID=2bab549;SWITCH=01;CMD=STOP;
20;07;Debug;RTS P3;;
2. Pair RFlink
10;RTS;2BAB550;0100;0;PAIR
20;0D;OK;
3. Send command to open or close gate
10;RTS;2BAB550;0;STOP;
20;0E;OK;
But when I send command to open gate, nothing happens. Can describe your steps how did you achieve to pair rflink with Exavia and commands you're using to open/close gate please?
Thanks a lot.
Errance
#7 Post by Errance » 09 Dec 2019, 15:06
You need to put your antenna on the control electronic target to pair your rflink for the first time. Like the remote in the documentation.
If it works, you'll show a light on the control.
Guigs71fr
#8 Post by Guigs71fr » 18 Oct 2020, 17:53
Salut,
Je fais remonter un vieux sujet mais j'ai vu que vous aviez réussi ou j'ai échoué :)
J'ai un SGA6000 mais globalement c'est la même carte éléctronique.
Pouvez vous m'aider ?
mrflop
#9 Post by mrflop » 05 Aug 2021, 16:00
I finally did it for the EXAVIA STAR.
I used a different pairing process.
For remote, you have to press the exavia board button for 2 seconds.
To enroll rflink, I pressed the exavia board button for 7 seconds.
After that I can control my gate motors:
To pair (after press the exavia board button for 7 seconds):
10;RTS;0F0F0F;0412;0;PAIR;
To open:
10;RTS;0F0F0F;0;UP;
To close:
10;RTS;0F0F0F;0;DOWN;
To stop:
10;RTS;0F0F0F;0;STOP;
Let's hope that it will help someone, I would love to read this message 2 hours ago :)
