WS2812
Ger
WS2812
#1 Post by Ger » 23 Nov 2015, 14:01
I am trying to create a version with WS2812 support.
I use the following library https://github.com/JoDaNl/esp8266_ws2812_i2s
I get errors, with the example i have no errors.
Anyone an idea what i am doing wrong?
Arduino: 1.6.5 (Windows 7), Board:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS)"
In file included from ESPEasy.ino:64:0:
C:\Program Files (x86)\Arduino\libraries\WS2812_i2s/ws2812_i2s.h:10:1: error: expected unqualified-id before 'extern'
extern "C"
C:\Program Files (x86)\Arduino\libraries\WS2812_i2s/ws2812_i2s.h:10:1: error: expected constructor, destructor, or type conversion before 'extern'
In file included from c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\new:40:0,
from c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\ext\new_allocator.h:33,
from c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\xtensa-lx106-elf\bits\c++allocator.h:33,
from c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\allocator.h:46,
from c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\memory:63,
from C:\Users\Ger\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\ESP8266WiFi\src/WiFiClient.h:28,
from C:\Users\Ger\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\ESP8266WiFi\src/ESP8266WiFi.h:32,
from ESPEasy.ino:161:
c:\users\ger\appdata\roaming\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\exception:35:37: error: expected declaration before end of line
#pragma GCC visibility push(default)
Fout bij compileren.
Dit rapport zou meer informatie hebben met
"Tijdens de compilatie uitgebreide uitvoer weergeven"
ingeschakeld in Bestand > Voorkeuren.
Deennoo
Re: WS2812
#2 Post by Deennoo » 02 Feb 2016, 11:56
there a really good sketch easy to understand and easy to build here :
http://pance.mk/index.php/wifi-light-wi ... uino-code/
It make run all the pixel to the same color, webinterface controled and well documented.
tozett
Re: WS2812
#3 Post by tozett » 02 Feb 2016, 15:37
another (old) example
but a lot of cool effect-routines in the arduino-source !!! ;)
http://funkboxing.com/wordpress/?p=2154
http://funkboxing.com/wordpress/wp-cont ... 1_POST.ino
Ger
Re: WS2812
#4 Post by Ger » 04 Feb 2016, 13:22
At the moment I use two projects with esp8266 arduino code using ws2812.
A ntp clock with ws2812 see website http://www.thelightclock.com/ github https://github.com/chrismelba/thelightclockwifi .
A hue bridge using ws2812 thanks to Deennoo github https://github.com/sticilface/Esp8266-Hue.
At home I use a couple of WS2812 led strips for lightning as described in the following post http://www.esp8266.nu/forum/viewtopic.php?f=6&t=198.
I would like to have a web interface to configure it, at the moment I am thinking of expanding the hue bridge to 300 lights and maybe building a web interface to configure the lights.
Deennoo
Re: WS2812
#5 Post by Deennoo » 04 Feb 2016, 14:32
On my side i'm looking for a way to drive all the led strip as a single bulb with huebridge sketch
Do you have an idea Ger?
Still for Ger, i start the same project as you need and get some cool résult :
https://github.com/deennoo/ESP8266-ws2812b
Use master sketch and have fun
Ger
Re: WS2812
#6 Post by Ger » 04 Feb 2016, 15:31
@Deennoo I think my original problem was a problem with a wrong library
I think you can use groups to use it as one bulb I am using Hueremote on a Ipad.
Do you know if you can control hue with sketches?
Deennoo
Re: WS2812
#7 Post by Deennoo » 04 Feb 2016, 16:37
i can't of course will try this app (offical one who i use doesn't allow more than 6 bulb/group, because of firmware bad reconizion i think).
does this group is well reconize by domoticz ?
Ger
Re: WS2812
#8 Post by Ger » 04 Feb 2016, 23:22
I don't see the HUE groups in Domoticz, I can create groups in Domoticz but the led color is individual configured at a led basis, not the group.
What I don't understand is why you would use WS2812 led's if you want them always all the same color I would use a 'normal' 12V RGB or RGBW strip.
They are cheaper and with the WS2812 strip if you use a long strip (5m) and full brightness the end of the strip will be less bright because it is 5V based and not 12V based I think. ;)
Deennoo
Re: WS2812
#9 Post by Deennoo » 05 Feb 2016, 07:12
On my side :
Dont want ans cant't put long led strip.
I already got some ws2801 and now ws2812b juste want to recycle them (fedup buying again and again).
Easy to powerup : only 5v and my max pixel number will be 30 pcs.
My wemos who provid 5v direct from USB can accepte them easily
Got 1 wemos + 15 pixels who run my sketch with 5v 750ma /230 adapter and all is OK since 3 days now.
By the way ESP Easy isn't a light project...
tozett
Re: WS2812
#10 Post by tozett » 06 Feb 2016, 23:04
just for the ws2812 lover, i surfed over this,
maybe an inspiration to bring here over? :mrgreen:
http://forkineye.com/espixelstick/
Deennoo
Re: WS2812
#11 Post by Deennoo » 07 Feb 2016, 18:11
Nice ! Thx
wutu
Re: WS2812
#12 Post by wutu » 14 Feb 2016, 10:04
tozett wrote:just for the ws2812 lover, i surfed over this,
I tested this on Christmas. DMX is not appropriate for wireless.
Better to me whether it controls already prepared animations in esp8266. With editable parameters.
Like here: https://github.com/sticilface/ESP8266-wifi
tozett
Re: WS2812
#13 Post by tozett » 14 Feb 2016, 10:16
cool, cool , i will consider get it working soon ..
:mrgreen:
edit: managed to compile it, had to remove one argument from a neopixel-call.
found this screenshots: https://github.com/sticilface/ESP8266-wifi/wiki
waiting for time to flash ...
tozett
Re: WS2812
#14 Post by tozett » 14 Feb 2016, 17:56
i fiddled with this,
but:
:cry:
seems far away from stable...
can only use pin TXD1 in the uart-driven neopixel lib, which means GPIO2 on my ESP12,
when the LED strip (8) is connected from power-on, it does not boot...
needed some reboot to connect to my wifi
webinterface somehow slow in comparison to ESPeasy
+ shows signal strengh of wifi lans,
+ ws2812 was on, for onetime (than esp crashed)
+ effects are in the source
+ presets are in the source
+ "MQTT commands control mostly everything."
...little bit more stable would be good, integration to ESPeasy would be great (but maybe better to run on an arduino-mini with extender...)
Deennoo
Re: WS2812
#15 Post by Deennoo » 14 Feb 2016, 20:11
Again thx for source will try it too !
Milight API ils quite easy to understand, but for a newbie on arduino sketch programming...not so easy to add.
But will try.
Deennoo
Re: WS2812
#16 Post by Deennoo » 14 Feb 2016, 21:28
60 min later i'm back, and please to say that Sticilface made a great job !
Of course that a bit slower on running effect, but impressive, it made all that i plan to do....and i will take 3 years to made it...
Actually i run it on a Wemos mini d1 + 15 pixel direct plug on it (5v gnd and data) and usb3 powered, and it works very nice
I saw that it's waiting for some UDP order, will try to investigate on.
edit : UDP : looks can be works on milight protocole, color looks reverted, can turn on but not turn off, and controlling only 1 pixel, this sketch is a bomb for me
tozett
Re: WS2812
#17 Post by tozett » 19 Feb 2016, 20:13
Deennoo
Re: WS2812
#18 Post by Deennoo » 21 Feb 2016, 10:03
Hum....no
PI Zéro + wifi dongle + sd card + led board.....to much marerial for my project
wutu
Re: WS2812
#19 Post by wutu » 24 Feb 2016, 16:40
Looks like sticilface sleeps not. So hopefully something will.
https://github.com/sticilface/Melvanimate
msev
Re: WS2812
#20 Post by msev » 04 Mar 2016, 11:59
Deennoo
Re: WS2812
#21 Post by Deennoo » 04 Mar 2016, 21:55
Can be, to try
msev
Re: WS2812
#22 Post by msev » 15 Mar 2016, 09:54
Guys I think the best way would be to use the FastLED library, it supports esp8266 out of the box and has a big community online. And this library support different variety of leds so it would be cool to support multiple types at once.
See here under supported platforms: https://github.com/FastLED/FastLED
The G+ community: https://plus.google.com/communities/109 ... 4227823508
Also I think this FastLED library has some animations included.
I'd really like for this to be implemented :D
tozett
Re: WS2812
#23 Post by tozett » 15 Mar 2016, 10:13
Is this really portable to esp8266?
There are critical Timings in the code...
msev
Re: WS2812
#24 Post by msev » 15 Mar 2016, 10:58
It says in the readme under Supported platforms: ESP8266 using the arduino board definitions from http://arduino.esp8266.com/stable/packa ... index.json
So it seems it supports ESP8266, also here a demo: https://www.youtube.com/watch?v=IGXInPlnvYc
And here: https://www.youtube.com/watch?v=3zQ8qC1KQgU
I don't know what the relation to ESP Easy firmware is, if it clashes somewhere, since I'm not a coder.
Deennoo
Re: WS2812
#25 Post by Deennoo » 15 Mar 2016, 16:04
Maybe ESPEasy have to simple reach the goal to be a Sensors FW and not a Lighting FW...
wutu
Re: WS2812
#26 Post by wutu » 09 Apr 2016, 17:43
Sticilface nicely tuned https://github.com/sticilface/Melvanimate.
With MQTT and can be controlled via http://pixelinvaders.ch/?page_id=160
On Wemos D1mini works well. Use the library from Adafruit.
Deennoo
Re: WS2812
#27 Post by Deennoo » 10 Apr 2016, 06:26
wutu wrote:Use the library from Adafruit.
Try to get it but facing to a lib problem.
Can you try to be more explicit please ? (or share your working lib if you can)
msev
Re: WS2812
#28 Post by msev » 10 Apr 2016, 10:29
No no I think you need to use Neopixelbus library by Makuna on github. Sticilface uses that one not the original adafruit one.
wutu
Re: WS2812
#29 Post by wutu » 10 Apr 2016, 19:38
msev: Course you're right, but it also uses https://github.com/adafruit/Adafruit-GFX-Library. That makes me a bit confounded.
Deennoo: I compiled with the Arduino IDE 1.6.8 and ESP8266 2.1.0, all other libraries in the last github version. If you prefer, write, I compile it for you. Just tell which devices.
Deennoo
Re: WS2812
#30 Post by Deennoo » 11 Apr 2016, 18:53
@Wutu, thnaks for your help, i appreciate this, but have to find a solution be my self, getting a .bin form someone help of course to reach final goal, but is not a goos solution to learn how it works.
Deennoo
Re: WS2812
#31 Post by Deennoo » 12 Apr 2016, 16:54
wutu wrote:msev: Course you're right, but it also uses https://github.com/adafruit/Adafruit-GFX-Library. That makes me a bit confounded.
Boring by searching lib again and again and again, no my problem is that i can't find FSBrowser.h....i manage to progress on compil using a neopixelbus animator version i get from 15/01/2016.
Please Wutu can you share your complied one ? does this version you get got spiffs files on ? or do i have to put them by my self ?
Edit : Finally I manage to compil and make it works.
