First of all, thanks for RFlink, i am very happy using it for my kaku-stuff ( nothing fancy, ... yet...).
Right now i am adding two coupled flamingo 21rf/2 smokedetectors.
However, I tried seeing both, but they are represented as one.
Is this by 'design' (i.e since they are coupled) or is there some way to get them both to show up in f.e. domoticz.
Thanks,
Alex.
fa21rf/2
Re: fa21rf/2
I have FA20rf, and all of them are seen as one, because they use the same address when they are coupled.If you want to see them individually, you must configure each as a an independent master.
Best regards,
Romain
Best regards,
Romain
Re: fa21rf/2
Thanks for your reply.
( I would like to keep them coupled).
I am wondering if there would be a way to distinguishes which one is causing the alarm. Even when they are coupled.mouette44 wrote:I have FA20rf, and all of them are seen as one, because they use the same address when they are coupled.If you want to see them individually, you must configure each as a an independent master.
Re: fa21rf/2
No that is not possible.
When you pair them, they all get the same id and send out the exact same signal.
Re: fa21rf/2
Ok, thanks. That's clear.
I will think of using separate groups to still get some idea where the alarm originated.
Alex.
Alex.
