Hi All,
By default ESP Easy Mega provide one Blynk HTTP testing controller that can retrieve data from Blynk sensor using Blynkget command. I wanted to retrieve the data from different Blynk sensors. So I modified C12.ino plugin. Removed the password from Blynk Controller. Now Blynk password can be entered in the Rule as below. I display all these values to OLED display connected to this espeasy controller.
on Rules#Timer=1 do
BlynkGet 2,1,KL9urJjJFTsxxxxxxOY0Bxu8nUq8Dy_V/get/D17 //Kitchen Gas
BlynkGet 4,1,KL9urJjJFTsxxxxxxOY0Bxu8nUq8Dy_V/get/V4 //Kitech temp
BlynkGet 1,1,fjdnwuXSbxxxxxxxVlvTYHNy8YeZC_HB8/get/V2 //sump pump
GPIO,12,0
TimerSet,2,5
Get data from Multiple Blynk sensors
Re: Get data from Multiple Blynk sensors
So for this use case we may need an extra Blynk command?
Can you make an issue for it (including the suggested code change) on GitHub?
I should post it on GitHub. I don't think we need any extra commands. same command can be used with multiple Blynk sensors. All we need is to put Blynk api_key in rule.
We don't need to enter controller password in Blynk controller.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 45 guests
