new Plugin not avaliable
hi,
i tried to add _P103_BLEMijia.ino to actual source.
build and upload was succeful (test_ESP32_4M316K) but device is not avalible.
what am i doing wrong.
this is the plugin https://github.com/enesbcs/ESPEasyRetro ... EMijia.ino .
thx
mod25
thx
mod25
Re: new Plugin not avaliable
Have you added in your configuration somewhere?
#define USES_P103
missed it. didn't know that. i have read https://www.letscontrolit.com/wiki/inde ... platformioAth wrote: ↑30 Apr 2020, 19:59 Have you addedin your configuration somewhere?Code: Select all
#define USES_P103
which config or where should it be added?!
thx
I think it should be added in define_plugin_sets.h, in the section that starts with #ifdef PLUGIN_SET_TESTING, but that's assuming that you have chosen a testing build in your platformio.ini (I'm using this one: default_envs = test_beta_ESP8266_4M1M for ESP8266 and test_ESP32_4M316k for ESP32)
It is already defined in the experimental set, so you could select a build environment for experimental, but I assume that might be quite big, or not have other plugins you require.
added in PLUGIN_SET_TESTING thx for the hint.Ath wrote: ↑30 Apr 2020, 21:22 I think it should be added in define_plugin_sets.h, in the section that starts with #ifdef PLUGIN_SET_TESTING, but that's assuming that you have chosen a testing build in your platformio.ini (I'm using this one: default_envs = test_beta_ESP8266_4M1M for ESP8266 and test_ESP32_4M316k for ESP32)
next error is now program size 2371498 bytes is to big... need to deselect other plugins...
thx
To disable other plugins, just add // in front of the #define USES_... lines for plugins you don't need.
thought so but after deactivated all testing plugins there where no changes also if i cleanded and rebuild firmware.
do not know what i'm doing wrong.
What value have you set for default_envs in your platformio.ini?
NB: I'm assuming you use VSCode with PlatformIO as a build environment, as you didn't mention anything about that... I'm not using, nor interested in, Arduino IDE
I'm using atom with platformio.
right now i'm using actual source with platformio.ini from github with some changes... playing right now with partiotions so that i have add a new csv with following values:
esp32_partition_no_OTA.csv
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x200000,
spiffs, data, spiffs, 0x210000,0x1F0000,
platformio_esp32_envs.ini
[esp32_common]
extends = common
platform = ${core_esp32_1_11_2.platform}
lib_ignore = AS_BH1750, ESP8266WiFi, ESP8266Ping, ESP8266WebServer, ESP8266HTTPUpdateServer, ESP8266mDNS, IRremoteESP8266, ESPEasy_ESP8266Ping, ESP32_ping, HeatpumpIR
lib_deps = https://github.com/TD-er/ESPEasySerial.git#v2.0.1, Adafruit ILI9341, Adafruit GFX Library
board_build.f_flash = 80000000L
board_build.flash_mode = dout
board_upload.maximum_size = 1900544
board_build.partitions = esp32_partition_no_OTA.csv
i 'm little bit afraid of partitions maybe it is just warning with the setting board_upload.maximum_size and there's enough space.
i think adding BLE with WIFI is to big but want to test it on ESPEasy.
thank you for your patience
mod25
[esp32_common]
extends = common
mod25
