Warema 8k hand transmitter
Post here about devices that are not yet or not fully supported
dproetel
#1 Post by dproetel » 02 Feb 2017, 21:13
good afternoon,
I try to connect a warema sender with 8 channels. Under device it shows:
rflinki 00006CA7 0 oben 6 Light/Switch Warema Open
but it seems that all 8 channels have the same entry. Any hints?
thanks in advance Daniel
Stuntteam
Site Beheer
Re: Warema 8k hand transmitter
#2 Post by Stuntteam » 03 Feb 2017, 00:49
Check your email..
kafe75
#3 Post by kafe75 » 11 Feb 2017, 10:12
good morning,
i´ve got the same problem with my 8k hand transmitter, controlling my roller shutters.
In domoticz the control command is recognized as warema protocol, but it´s always the same address.
Do i have to pair the devices with my master control unit?
Stuntteam
Site Beheer
#4 Post by Stuntteam » 11 Feb 2017, 10:51
Check your email..
Des0re
#5 Post by Des0re » 21 Aug 2019, 18:07
I also have a problem with warema EWFS
Rflink recognises the switches. But i cannot control with rflink.
tkospace
#6 Post by tkospace » 09 Jun 2020, 23:28
Stuntteam wrote: 11 Feb 2017, 10:51 Check your email..
I have the same problem.
Could you send me the information too?
Br,
tkospace
intelligenzbestie
#7 Post by intelligenzbestie » 23 Jun 2020, 21:16
I would be interested as well.
I have a Warema EWFS Weather Station Plus combined with an adapter to control an even older Warema awning.
I also have a handheld transmitter to manually move it out and in.
I managed to retrieve the commands for out and in using a Signalduino at 433 MHz and I can "replicate" them as raw messages so this works.
But I would be intested in the data of the weather station because it contains a wind and rain sensor.
And I would like to "see" when the weather station "commands" the awning to move out or in.
Thanks,
best regards
Richard
Stuntteam
Site Beheer
#8 Post by Stuntteam » 24 Jun 2020, 00:05
For new/unknown devices follow the instructions here: http://www.rflink.nl/blog2/development
Tom_77
#9 Post by Tom_77 » 29 May 2024, 18:56
Is there a special thing with the Warema EWFS 8K Controller?
I try to control my Warema venetian blinds with RFLink but no Command works.
I use a Nodo RFLink Gatewayboard (RLink Firmware Version: 1.1 Revision: 51) and have a Warema EWFS 8K Controller.
For example, when pushing a Button of the Controller, I receive in the RFLink Loader (V1.11) screen:
20;68;Warema;ID=ae16;SWITCH=01;CMD=DOWN;
I now try to send in the "Command to Send"-Field in RFLink Loader the following:
10;Warema;ae16;1;DOWN;
Receiving the following:
20;88;OK;
But the Warema venetian blinds are not moving?
tuxinger
#10 Post by tuxinger » 23 Jul 2024, 08:07
Same here, got a RFLink from nodoshop. I can see the commands transmitted by the remote, but if I send, nothing happens.
Can anyone please post a brief description how to use RFlink with warema ewfs. I think we are missing the side-channel learning, but as the code is not Opensource and no docs given I have no clue how to do it.
Users browsing this forum: Anthropic Claude Bot [bot] and 13 guests
