Hi Guys
I'm looking for hookup this device,
He act :
1: Brown wire (VCC) Power +5V~24V (Power+)
2: Yellow wire (OUT) Signal output
3: Black wire (M) Output level (positive output or negative output) control
When the black wire connect the high level, yellow wire is positive output signal wire, the output is high level when the object is sensed.(NPN closed)
When the black wire connect the low level, yellow wire is negative output signal wire, the output is low level when the object is sensed(NPN disconnect)
4: Blue wire(GND) Ground wire(connect Power-)
Which device I should use and any clue for the wiring ?
Vic
XKC Y25 T12V liquid level switch water non contact
Re: XKC Y25 T12V liquid level switch water non contact
Ok, I got it working with "Switch input" device and "Yellow wire (OUT) Signal output" on GPIO.
My pool skimmer told you tks
Not sure if it's normal behaviour, but device send randomly state to domoticz
https://www.dropbox.com/s/5098z1n98fom9 ... .jpeg?dl=0
Good day Forum,
Just got my sensor XKC-Y25-PNP and hooked it up on a Wemos D1 mini board
Brown >> VCC 5 v
Yellow >> Data, GPIO 12, ( D6 )
Black >> GND
When i power the board, the responses.
The light is switching on/of when I go over a water (hand) object.
However, ESPEasy is not responding.
I have setup a device type: input Switch
but this is not responding (in de log)
Anyone any idea about the correct settings/configuration for this??
Thanks for time and response in advance.
Arjen
Brown >> VCC 5 v
Black >> GND
Arjen
