Need some help
I have ads1115 and want to use the 4 inputs. I only can chose one in the web interface, How to use the other three?
ADS 1115 input
Re: ADS 1115 input
Add 3 more instances of the plugin in the Devices list and select the appropriate (input) connections from the 'Input Multiplexer' combobox.
Be sure to give the devices unique names, the Values names can be the same, or you can change them as desired.
