MQTT Syntax adafruit motor shield (Stepper)
IOT'er,
Anyvbody experience with the Adafruit Motorshield with Stepper driver?
I need the Rule for commanding the rotation and the release.
I'm guessing that this should be done within 1 or 2 rules in ESPeasy, and kicked of with a MQTT cmd, True?
If so what is this Syntax, or how to get it?
I managed to get switches and sensors working!
Kind regards,
Kirelam
Kind regards,
Kirelam
Re: MQTT Syntax adafruit motor shield (Stepper)
No it is a plugin that is in beta.
https://www.letscontrolit.com/wiki/inde ... ield_v2%22
Works like a charm for me under http. But i am moving to HA so i need to control it through MQTT.
Kind regards,
Kirelam
Kind regards,
Kirelam
Ah this one, with clearly a very minimalistic styled documentation: https://espeasy.readthedocs.io/en/lates ... #p048-page
From the comments in the source code:
MotorShieldCMD,<DCMotor>,<Motornumber>,<Forward/Backward/Release>,<Speed>
MotorShieldCMD,<Stepper>,<Motornumber>,<Forward/Backward/Release>,<Steps>,<SINGLE/DOUBLE/INTERLEAVE/MICROSTEP>
Will try thanx!!
Anyone an idee how the MQTT commands look?
I cannot get the module to recognize the commands
Well sending via MQTT is not something I tried myself.
But in general, the commands should be formatted just as if you sent them via the command field on the tools page.
The options are almost all strings, so:
- Command is MotorShieldCMD
- Motor type = "DCMotor" or "Stepper"
- Motornumber is an int.
- action is Forward/Backward/Release
- action parameter is an int (0 ... 255)
So an example of a command can be:
MotorShieldCMD,DCMotor,0,Forward,10
I also added the same info to the main documentation, to help others too.
So something like this?
MQTT: ChickenBot/MotorShieldCMD,Stepper,M1
And than with the load: Release or backward,2000,double
Cause this does not work with Home Assistant.
This is what i have in Home assistant now:
- platform: mqtt
state_topic: "/ChickenBot/Button/State"
command_topic: "ChickenBot/MotorShieldCMD,Stepper1"
payload_on: Release
optimistic: true
qos: 0
retain: true
value_template: '{{ value.x }}'
I am vallueing your advice!!
Greetz,
Kirelam
- platform: mqtt
payload_on: Release
optimistic: true
qos: 0
retain: true
Greetz,
Kirelam
2000 is not in the range of 1...255.
Ok, but the release command is also not coming through?
That one has a simple syntax with no parameter!
Like I said, I haven't tried the commands via MQTT myself.
According to the documentation, you should add "cmd" to the topic: https://espeasy.readthedocs.io/en/lates ... -reference
The command itself does work when you enter it in the command field on the tools page?
