wemos + two led
pawell32
wemos + two led
#1 Post by pawell32 » 22 Sep 2020, 08:50
i have a wemos d1 + two display 7-segment led.
I want to show the outside temperature on the first display and the inside temperature on the second display.
on BM280#Temperature do
7dt,[BM280#Temperature]
on DHT11#Temperature do
7dt,[DHT11#Temperature]
it can be divided into two displays ?
Re: wemos + two led
#2 Post by TD-er » 22 Sep 2020, 11:05
Not sure if the plugin for the 7-segment display does allow for multiple instances, so you should try it yourself.
If it does support multiple instances, you're still left with the addressing of the other display as there doesn't seem to be room for a task index number in the commands.
Also the documentation isn't really helpful here ( https://espeasy.readthedocs.io/en/lates ... #p057-page ) :(
pawell32
Re: wemos + two led
#3 Post by pawell32 » 22 Sep 2020, 11:38
thanks,
also did not find
Re: wemos + two led
#4 Post by Ath » 22 Sep 2020, 13:04
That will be available when a) the plugin allows multiple instances and b) PR#3198 is merged.
