Visonic Power Max 868Mhz
Post here about devices that are not yet or not fully supported
ayasystems
#1 Post by ayasystems » 01 Sep 2016, 22:28
Is visonic power max 868Mhz supported??
Here is my log
http://pastebin.com/UsuHMzDc
Is normaly have several entries on debug mode per second? It is not normal in my 433 device, only in 868
About visonic:
http://www.visonic.com/spain/es/Product ... ct-234-wpp
MCT-234 ESPECIFICACIONES:
Frecuencias (MHz): 433.92 MHz ú 868.95, (especificar según necesidades)
Modulación: ASK (ON-OFF keying)
Duración de Transmisión: Cada botón al ser presionado causa una transmisión d hasta 2 seg.
Alimentación: Pila alcalina de 12 V. tipo GP23A o equivalente.
costo
Re: Visonic Power Max 868Mhz
#2 Post by costo » 01 Sep 2016, 23:59
It specifies this device as: Encoding: 28-bit ID, 4-bit and 32-bit function code jump.
I think this means the code changes every time you push a button. That is called a rolling code.
RFLink and most universal encoders/decoders cannot generate a rolling code.
Stuntteam
Site Beheer
#3 Post by Stuntteam » 02 Sep 2016, 09:22
Generating rolling codes is not needed to receive alarm system sensors.
ayasystems
#4 Post by ayasystems » 02 Sep 2016, 09:32
So... Could be decoded Visonic 868Mhz by Rflink?
costo
#5 Post by costo » 02 Sep 2016, 23:08
In theory, if RFLink has the right plugin, this code could be decoded.
That is, it would show you the 28 bit ID and probably the 4 bit function.
As far as I know, for now this plugin has not been written .
juanjogarciac
#6 Post by juanjogarciac » 08 Nov 2016, 21:28
Hi all,
In Europe Visonic work over 868Mhz. How can help you to support this device? Is the code different with 433Mhz? I believe we only need to receive changes and we don't need rooling.
Thank you !!
Juanjo
inversions
#7 Post by inversions » 09 Oct 2020, 21:58
Has there been any progress in supporting Visonic 868MHz devices?
I bought my RFLink believing Visonic were already supported, but it seems not.
It would be really great if these devices could be supported.
