I have make some PCB for esp8266
It's a universal board with several I/O
included 220 powersupply
2x I2c
1x Nextion Display
4x Relais NC / NO
1x 4 outputs ttl
1x 8 Input/output
1x expansionboard
adval40
Universal PCB relais / I/O / NEXTION display
- RelaisBoard20190421-Schematic.png (68.03 KiB) Viewed 6236 times
- RelaisBoard20190421.png (148.38 KiB) Viewed 6236 times
Re: Universal PCB relais / I/O / NEXTION display
Nice work, thanks for sharing.
The Nextion's hardware serial I/O needs a transistor buffer to prevent boot lock up. See the wiki:
https://www.letscontrolit.com/wiki/inde ... le=Nextion
Transistor is inside Q1 bc557
Ad (adval40)
Ad (adval40)
Very good!Transistor is inside Q1 bc557
I know that there are many services that can help with this. I am interested- how much it costs? I had another question but also on this topic, I decided to make a circuit check and looked for this service, it helped me because I would have an old monitor and I did not understand why I had errors. My wife remembered that she had a similar problem as me and helped me find that service. I spent a lot of time searching... As a result, they fixed the monitor:) I like to play computer games, so the monitor was important to me. To be honest I am not an expert but I hope this information helps you.
