A request that started here
This is intended as a Request for Comment/discussion piece. Please reply if you think you have something useful/relevant to add.
Goal: Present Task data more userfriendly on the Devices page
The challenge:
- Some devices hold Values data that is either not very comprehensible or even incomplete when displayed as a mere numerical value
Examples:
- P008 RFID, P016 IR, P017 PN352 and P040 ID12 -> Store their data in 2 variables (to avoid losing accuracy), but only the lower 16 bits are displayed
- Dummy Devices can be used to store all kinds of numerical data -> Storing %syssec_d% gives a number like 12345, but it is quite hard to comprehend that it is actually 03:25:45 in HH:MM:SS format
- Some numerical data would be more useful when translated to an enumerator-like string (0-off, 1-ON) etc. (Some formatting options are already available in the [taskname#varname#transformation#justification] processing)
- Temperatures, barometric pressures, etc. would be helped when showing a unit before or after the value
To avoid overly complex code, as mentioned in the thread above as seen in the Domoticz plugins/controllers for receiving/sending values, there should probably be multiple, area-specific, solutions to these multiple cases.
A few possible solutions/directions I've been thinking of:
1) Plugins that store their result in multiple variables (P008, P017, P040)
-> A plugin-event that is called while displaying the Devices page, and the possibly dashboard.esp page?, that returns a presentation-version (string) for all possible values (1..4) of the plugin (event->String1..4?)
: Quite easy to implement, as it is controlled by plugin authors
2) Dummy devices, or more generic, numerical data as transformed data
-> Some kind of formatting formula to transform the numeric data to the required output
: This could require some settings space to store these formulas, and that can turn out to be somewhat challenging
: Could be handled by rules/events, but currently a) returning a value from rules is 'difficult' and b) string support in ESPEasy is limited
RFC: How to custom-format display Task data in the Devices page
Re: RFC: How to custom-format display Task data in the Devices page
Please have a look at those plugins where "PLUGIN_WEBFORM_SHOW_VALUES" is implemented.
I think that does cover all the issues you're seeing?
On top of that I guess we may need to have a look at the "UserVar" data as it is now used.
Every piece of code can access it, which may lead to a plethora of implementations to handle special cases.
Maybe we should make it just an array of bytes which will be read by default as 4 floats, or in some other form based on the current sensor Vtype.
For example Sensor_VType::LONG is now used in a very inefficient way to store its value in 2 floats to not loose any resolution.
But in the same 16 bytes per task, you can store whatever you like.
- 4x 32 bit uint/int
- 4x float
- 8x 16 bit int with some standard factor (see for inspiration the packed raw data format I added for the LoRaWAN controller)
- etc.
So I guess that's what you meant by extending the Sensor_VType enum?
If that's the reason to do it, then I am quite fond of the idea, as long as we take a very good look at the Domoticz controllers as they really rely on this type.
So maybe we need to add a very specific field in the DeviceStruct to add a "Domoticz override sensor VType" only to be set for a very specific plugin?
- 4x float
- etc.
That should take care of item 1) indeed, but the documentation on this part is quite sparse, to say the least, that's probably why I didn't understand how this is to be used.
No, as there is no way to format the data in a Dummy Device, you would need some kind of typing or user-controlled formatting, as it is very likely different for every instance used.
Yes, something in this direction is the way to go, though 16 bytes isn't much space, but it'll have to suffice for now I think.TD-er wrote: ↑22 Jan 2021, 21:43 On top of that I guess we may need to have a look at the "UserVar" data as it is now used.
- 4x float
- etc.
I wasn't trying to extend that enum just yet, more like trying to get custom formatting on task values.TD-er wrote: ↑22 Jan 2021, 21:43 So I guess that's what you meant by extending the Sensor_VType enum?
Hadn't yet found the special handling of Sensor_VType::LONG before (but now I have), so the RFID tags are actually shown correctly, great! (Have no RFID reader available to validate...)
Users browsing this forum: Ahrefs [Bot] and 14 guests
