If I call by http an event it is done partially, during the processing the esp32 reboots.
here is a log of it. the log is from web, I do not know if it is complete.
91244: Dummy: value 1: -1
91246: Dummy: value 2: 0
91247: Dummy: value 3: 0
91249: Dummy: value 4: 0
91265: EVENT: Z2#All=-1,0,0,0
91685: EVENT: Z3#All=-1,0,0,0
96006: WD : Uptime 2 ConnectFailures 0 FreeMem 205632 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
99887: HTTP: event,Closeall
99909: EVENT: closeall
99941: ACT : event,ControlZ1=100
99943: EVENT: ControlZ1=100
100111: ACT : Let,1,100
100362: ACT : logentry,Z1_c_comp
100364: Z1_c_comp
100366: ACT : gpio,2,0
100368: GPIO : port#2: set to 0
100370: ACT : TimerSet,8,20+2
100373: ACT : delay,250
100625: ACT : LongPulse,33,0,20
100628: GPIO : port 33. Pulse set for 20000 ms
100630: ACT : gpio,32,1
100632: GPIO : port#32: set to 1
100634: ACT : LongPulse,22,0,20
100636: GPIO : port 22. Pulse set for 20000 ms
100638: ACT : gpio,23,1
100639: GPIO : port#23: set to 1
100641: ACT : TimerSet,2,20
100645: ACT : TaskValueSet,2,4,1
100650: ACT : TaskValueSet,2,1,100
100655: ACT : TaskValueSet,2,2,100
100660: ACT : TaskValueSet,2,3,100
101224: ACT : event,ControlZ2=100
101226: EVENT: ControlZ2=100
101567: ACT : Let,4,100
101775: ACT : logentry,Z2_c_comp
101777: Z2_c_comp
101778: ACT : gpio,2,0
101780: GPIO : port#2: set to 0
101782: ACT : TimerSet,8,20+2
101786: ACT : delay,250
102038: ACT : LongPulse,13,0,20
102041: GPIO : port 13. Pulse set for 20000 ms
102043: ACT : gpio,27,1
102045: GPIO : port#27: set to 1
102047: ACT : LongPulse,26,0,20
102049: GPIO : port 26. Pulse set for 20000 ms
102051: ACT : gpio,25,1
102053: GPIO : port#25: set to 1
102055: ACT : TimerSet,4,20
102059: ACT : TaskValueSet,3,4,1
102065: ACT : TaskValueSet,3,1,100
102070: ACT : TaskValueSet,3,2,100
102075: ACT : TaskValueSet,3,3,100
4723: WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
4724: WIFI : DHCP IP: 192.168.10.233 (RollladenManager) GW: 192.168.10.1 SN: 255.255.255.0 duration: 24 ms
4735: WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
4736: WIFI : Scan finished, found: 5
4737: UDP : Start listening on port 8266
4737: firstLoopConnectionsEstablished
4764: Dummy: value 1: -1
4765: Dummy: value 2: 0
4790: Dummy: value 1: -1
4792: Dummy: value 2: 0
4794: Dummy: value 3: 0
4795: Dummy: value 4: 0
4820: Dummy: value 1: -1
4822: Dummy: value 2: 0
4823: Dummy: value 3: 0
4825: Dummy: value 4: 0
4849: Dummy: value 1: -1
4851: Dummy: value 2: 0
4852: Dummy: value 3: 0
4854: Dummy: value 4: 0
4878: Dummy: value 1: -1
4891: EVENT: TaskInit#SZ=1,0
5316: EVENT: TaskInit#Z1=2,0
5755: EVENT: TaskInit#Z2=3,0
6200: NTP : NTP replied: delay 10 mSec Accuracy increased by 0.971 seconds
6201: Time set to 1611869164.971
6202: Current Time Zone: DST time start: 2021-03-28 02:00:00 offset: 120 min STD time start: 2021-10-31 03:00:00 offset: 60 min
6203: Local time: 2021-01-28 22:26:04
6207: EVENT: Clock#Time=Thu,22:26
6703: EVENT: TaskInit#Z3=4,0
7168: WD : Uptime 0 ConnectFailures 0 FreeMem 205872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
7179: EVENT: TaskInit#Boot=5,0
7662: EVENT: WiFi#ChangedAccesspoint
8088: EVENT: WiFi#ChangedWiFichannel
8506: EVENT: WiFi#Connected
8957: EVENT: SZ#All=-1,0
9384: EVENT: Z1#All=-1,0,0,0
9800: EVENT: Z2#All=-1,0,0,0
10246: EVENT: Z3#All=-1,0,0,0
10662: EVENT: Boot#All=-1
11079: EVENT: Time#Initialized
30225: Dummy: value 1: -1
30227: Dummy: value 2: 0
30238: EVENT: SZ#All=-1,0
30686: Dummy: value 1: -1
as the rules are quite big I did pastebins. rules2 to rules4 are the same, except other variables, other timers, other taskvaluesets and other gpio pins.
rules1: https://pastebin.com/pcBy5Dxi
rules2: https://pastebin.com/YdGDNZ7G
rules3: https://pastebin.com/BSR7P2hN
rules4: https://pastebin.com/5FhzVqfu
any ideas what is causing?
thanks.
BR
Alois
sysinfo:
{"System":{
"Build":20111,
"Git Build":"",
"System Libraries":"ESP32 SDK v3.2.3-14-gd3e562907",
"Plugin Count":47,
"Plugin Description":"[Normal]",
"Local Time":"2021-01-28 22:39:33",
"Unit Number":80,
"Unit Name":"RollladenManager",
"Uptime":13,
"Last Boot Cause":"Cold boot",
"Reset Reason":"CPU0: Software reset CPU CPU1: Software reset CPU",
"Load":23.33,
"Load LC":1187,
"CPU Eco Mode":"false",
"Free RAM":199256
"WiFi":{
"mDNS":"RollladenManager.local",
"IP Config":"DHCP",
"IP Address":"192.168.10.233",
"IP Subnet":"255.255.255.0",
"Gateway":"192.168.10.1",
"STA MAC":"7C:9E:BD:F8:F8:08",
"DNS 1":"192.168.10.1",
"DNS 2":"0.0.0.0",
"SSID":"KlinglAIRDMZUG",
"BSSID":"00:1F:F3:C1:F8:1A",
"Channel":2,
"Connected msec":810000,
"Last Disconnect Reason":1,
"Last Disconnect Reason str":"(1) Unspecified",
"Number Reconnects":0,
"Force WiFi B/G":"false",
"Restart WiFi Lost Conn":"false",
"Periodical send Gratuitous ARP":"false",
"Connection Failure Threshold":10,
"RSSI":-71
"nodes":[
{"nr":10,
"name":"WohnzimmerDimmer",
"build":20103,
"platform":"ESP Easy Mega",
"ip":"192.168.10.244",
"age":0
},{"nr":20,
"name":"Spieleraumheizung",
"build":20111,
"ip":"192.168.10.243",
"age":0
},{"nr":80,
"name":"RollladenManager",
"build":20111,
"platform":"ESP Easy 32",
"ip":"192.168.10.233",
"age":1
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"S",
"NrDecimals":0,
"Value":-1
{"ValueNumber":2,
"Name":"M",
"NrDecimals":0,
"Value":0
"DataAcquisition": [
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":30,
"Type":"Generic - Dummy Device",
"TaskName":"SZ",
"TaskDeviceNumber":33,
"TaskEnabled":"true",
"TaskNumber":1
"TaskValues": [
{"ValueNumber":1,
"Name":"S",
"NrDecimals":0,
"Value":-1
{"ValueNumber":2,
"Name":"SL",
"NrDecimals":0,
"Value":0
{"ValueNumber":3,
"Name":"SR",
"NrDecimals":0,
"Value":0
{"ValueNumber":4,
"Name":"M",
"NrDecimals":0,
"Value":0
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":30,
"TaskName":"Z1",
"TaskNumber":2
"TaskValues": [
{"ValueNumber":1,
"Name":"S",
"NrDecimals":0,
"Value":-1
{"ValueNumber":2,
"Name":"SL",
"NrDecimals":0,
"Value":0
{"ValueNumber":3,
"Name":"SR",
"NrDecimals":0,
"Value":0
{"ValueNumber":4,
"Name":"M",
"NrDecimals":0,
"Value":0
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":30,
"TaskName":"Z2",
"TaskNumber":3
"TaskValues": [
{"ValueNumber":1,
"Name":"S",
"NrDecimals":0,
"Value":-1
{"ValueNumber":2,
"Name":"SL",
"NrDecimals":0,
"Value":0
{"ValueNumber":3,
"Name":"SR",
"NrDecimals":0,
"Value":0
{"ValueNumber":4,
"Name":"M",
"NrDecimals":0,
"Value":0
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":30,
"TaskName":"Z3",
"TaskNumber":4
"TaskValues": [
{"ValueNumber":1,
"Name":"Watcher",
"NrDecimals":0,
"Value":-1
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":60,
"TaskName":"Boot",
"TaskNumber":5
"TTL":30000
