I2C Soil moisture sensor
Patou
Re: I2C Soil moisture sensor
#51 Post by Patou » 20 May 2021, 01:26
Hello André,
I am really interested in your moisture sensor.
Did you manage to make it work ?
Patou
rieders
#52 Post by rieders » 20 May 2021, 14:30
I was able to use part of the sensor.
Unfortunately, the gloss wasn't read correctly.
The other problem was that I couldn't reliably integrate the sensor.
First I have to press the button several times. It seems more of a coincidence than a methodology.
Maybe there is firmware for the sensor that "only" transmits the measured values.
I don't need the button, battery holder and buzzer.
I hope I could go on with you.
Greetings André
