KWH Counter
prutzer
KWH Counter
#1 Post by prutzer » 16 Jun 2020, 18:29
Hi All,
I have searched the whole internet, but i can not find a working solution to build a KWH meter with a D1 mini and a KWH meter.
What I have done:
I have a KWH meter. 1000imp per kwh and connected it to D5:
ESP Easy is configured as follow:
Result with a 500W balast:
W: is sometimes 1, and KWH is counting the pulses.
When I remove the calculation, the results are the same.
What am I doing wrong?
Re: KWH Counter
#2 Post by grovkillen » 16 Jun 2020, 19:08
Your time/interval is 10 seconds that mean that your momentary formula is correct. I have done the same on my energy meter here at home and it work just fine. The only thing I do different is that I have 2 decimals instead of zero... and D3 instead of D5.
Re: KWH Counter
#3 Post by TD-er » 16 Jun 2020, 19:29
What do you mean by the "total count is not persistent" you wrote in the image?
prutzer
Re: KWH Counter
#4 Post by prutzer » 17 Jun 2020, 08:50
If I use the normal version of ESP easy mega this text is automaticly added. "total count is not persistent"
In the dev version there is no such text.
I think it is strange that kwh is just counting the pulses. The formula does nothing.
I would like to see bij W the power usage at the moment and by KWH the power usage total.
I will add 2 decimals and try again.
Re: KWH Counter
#5 Post by TD-er » 17 Jun 2020, 09:06
Ah there has been a report about the formula not working for the pulse counter (and another plugin)
prutzer
Re: KWH Counter
#6 Post by prutzer » 17 Jun 2020, 10:16
Aaah so it is a known bug / problem?
2 decimals are also not working and not showing.
Which version of ESP easy do I have to use for a working solution?
Re: KWH Counter
#7 Post by TD-er » 17 Jun 2020, 12:26
prutzer wrote: 17 Jun 2020, 10:16 [...]
I think a future one, as it has not yet been fixed.
You can also do calculations in the rules.
prutzer
Re: KWH Counter
#8 Post by prutzer » 12 Jun 2021, 17:20
I tried this solution again and it looks like the bug is still there.
I tried Release mega-20210223 (Normal) and ESP_Easy_mega_20210114_energy_ESP8266_4M1M.
What rules do I have to make to calculate the energy usage in watts?
Something like this?
on Airco#Count do
SendToHTTP Domoitczip,port,/json.htm?type=command&param=udevice&idx=156&nvalue=0&svalue=[Airco#Count]*3600/10 //Sent to Domoticz
Re: KWH Counter
#9 Post by Ath » 12 Jun 2021, 19:09
That'll fire an update to Domoticz on every pulse of the counter, not sure if Domoticz likes that...
You'd better send that only once a minute or similar frequency:
And just for fun, I'd do the calculation before building the url for Domoticz
on system#clock=All,**:** do
  let,1,[Airco#Count]*360 // *3600/10 == *360, why do an unneeded division?
  SendToHTTP Domoitczip,port,/json.htm?type=command&param=udevice&idx=156&nvalue=0&svalue=[var#1] //Sent to Domoticz
prutzer
Re: KWH Counter
#10 Post by prutzer » 12 Jun 2021, 19:43
Hi ATH,
Thanks a lot for the script!
Wil it run the script every 10 seconds If I change it to:
on system#clock=All,**:**:* do
If I test it, domoticz does not get any updates.
If I do it manually: http://domoticzip:port/json.htm?type=command&param=udevice&idx=156&svalue=1000 it works.
ESP Easy log:
730433: EVENT: Airco#Count=6
730533: EVENT: Airco#Total=49
730633: EVENT: Airco#Time=31
prutzer
Re: KWH Counter
#11 Post by prutzer » 12 Jun 2021, 19:48
I found a working soliotion: Thanks to Ath!
on Airco#Count do
  SendToHTTP ipdomoticz,port,/json.htm?type=command&param=udevice&idx=156&nvalue=0&svalue=[var#1] //Sent to Domoticz
Set the device at 10 seconds:
Hardware: D5 to S0+ and ground to S0-
1000 pulses/kwh
Domoticz: Create a virtual device Electric Instant + counter. Edit this device and set it to computed.
Re: KWH Counter
#12 Post by Ath » 12 Jun 2021, 20:21
Yes, the system#clock interval is max. 1 per minute, if you need a shorter interval you can set a loop-timer:
on system#boot do
  loopTimerSet,1,10
on rules#timer=1 do
But your solution also works fine, so just keep that ;)
An actual improvement would be to use the %eventvalue1% argument that is passed to the event:
on Airco#Count do
  let,1,%eventvalue1%*360 // *3600/10 == *360, why do an unneeded division?
The advantage is that %eventvalue1% holds the value of that variable at the moment the event was generated, and, as rules can be delayed during execution, the count value could have changed in the meantime.
prutzer
Re: KWH Counter
#13 Post by prutzer » 15 Jun 2021, 19:29
Thanks for the improvement!
I will at it to the script!
Thanks a lot!
