I would like to test the serial connection between my PC with terminal and Telnet with a WEMOS D1 mini. It works by sending characters from Telnet to serial terminal but I get nothing when sending characters from serial terminal. Is there a particular configuration to set up in EspEasy?
PC Telnet -> WEMOS ESP -> PC USB Terminal : OK
PC USB Termnal -> WEMOS ESP -> PC Telnet : KO, no character received
My configuration :
Issue about Serial Server Device
- 1 - device.png (38.76 KiB) Viewed 4581 times
- 1 - config.png (18.07 KiB) Viewed 4581 times
Re: Issue about Serial Server Device
You should disable the Serial Port checkbox on the Tools/Advanced screen, as it will conflict with the Serial Server device.
After disabled the serial port, i still have the same problem.
i tried with an ESP32 and the last firmware without success.
I don't understand...
What do you send to the ESP?
Do you end with CR (ASCII code 13) and/or LF (ASCII code 10) ?
Is the baud rate set correct on both sides?
Juste send test with ascii characters...
I use the Arduino terminal with CR/LF checked.
If I reset the serial interface, I received some logs in serial terminal and yet I deactivated the serial logs
