A few months ago I made a couple of ESP8266 boards (Looky Wifi), many times I had problems with the DS18B20 Sensors.
Now i have a Project where a DS18B20 Sensor is 20 Meters Deep in the Ground, the Reading of this sensor was not possible, i got only Read errors.
At home I connected a DS18B20 sensor to the ESP8266 Board, first with a 2m cable that worked and then with a 70m cable what didn't work.
Then I measured with the osciloscope the signal at the end of the line, as you can see on the Pictures the pullup is way too weak @70m Cable!
Lesson learned
Just want share my experience
