Konfig for AZ-Touch with ESP32?
Hi there,
I have an AZ-Touch MOD display with ESP32 from AZ-Delivery. I flashed this with the current ESP Easy. Unfortunately I cannot find the correct port assignment for the display.
Does anyone have the configuration for the display and maybe a few examples for the control.
kindly regards
Gudi
kindly regards
Gudi
Re: Konfig for AZ-Touch with ESP32?
I assume it is this display: https://www.hwhardsoft.de/english/proje ... touch-esp/
On that page you have the schematics: Schematic AZ-Touch V01-03
Looks like the backlight is a bit different between ESP8266 and ESP32.
So for ESP32 you need to look for "LED32" and for ESP8266 the "LED" pin.
T_IRQ = GPIO-2
T_CS = GPIO-14
MISO = GPIO-19
SCK = GPIO-18
MOSI = GPIO-23
DC = GPIO-4
RESET = GPIO-22
CS = GPIO-5
LED32 = GPIO-15
Beeper = GPIO-21
T_IRQ = GPIO-2
T_CS = GPIO-14
MISO = GPIO-19
SCK = GPIO-18
MOSI = GPIO-23
DC = GPIO-4
RESET = GPIO-22
CS = GPIO-5
LED32 = GPIO-15
Beeper = GPIO-21
Some basic examples are found in the _P095_ILI9341.ino source code file (available on GitHub).and maybe a few examples for the control.
A more readable version of commands supported is in the RTD documentation: https://espeasy.readthedocs.io/en/lates ... #p095-page
Thank you for your tips. I had already found the pages and implemented the port configuration as follows. Unfortunately the commands don't work. The display remains dark.
I was hoping that someone would already use the display. I would like to use it to build a level measurement for my cistern. With a ToF sensor VL53L0X.
Can you recognize my mistake?
Does it light up if you submit this command from the tools page?
That should turn on the backlight for the display, as without it it can be very dark.
gpio,15,1
Thank you, that was the right hint. The display starts with gpio,15,0
Then I can write the first "Hello World".
I think I can continue to work with that. I think that should work with tftcmd,on
You can also use the pwm command to put a pulse signal on that gpio to get less backlight than 100%
pwm,15,<duty> // <duty> is a numeric value from 0..1023, giving a range from 0 to 100%
