I have recently bought and built an Rflink for 868mhz devices in order to use to control my home shutters.
My installation is actually manage via a remote Delta Dore Tyxia 253 and receivers Tyxia 4630 plugged at each shutters.
Depending on the website you are looking at the receiver is sometimes described as working on X2D protocol and sometimes on X3D protocol.
I am pretty sure that it is an X2D one as it is clearly written on the remote that the protocol is X2D and as the receivers are dated from 2011.
After assembly and soldering of the different part of the Rflink, everything seems to work properly as when I press on a button of the remote, the Rflink receives data properly but unfortunately, I do not manage to associate the receivers with the Rflink when trying to send a command.
Here is what I have when I press one time on the remote while it is in association mode + debug mode on Rflink Loader:
And here is what I have when I press several times the "up" button when the remote is in association mode with debug mode disabled:20;06;DEBUG;Pulses=511;Pulses(uSec)=2550,300,330,300,330,300,330,300,330,90,120,90,120,90,120,90,120,90,120,90,120,300,120,90,330,300,330,300,330,300,120,90,330,300,330,90,120,300,330,90,120,300,330,120,120,300,330,90,120,300,120,120,330,300,330,300,330,300,330,300,330,120,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,120,330,300,120,90,330,120,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,90,120,90,120,300,330,90,120,300,330,120,120,300,330,120,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,90,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,300,120,90,120,90,120,90,120,90,120,90,120,90,330,120,120,300,330,300,330,300,330,90,120,330,330,300,120,90,330,330,120,90,330,300,120,90,330,300,120,90,330,90,120,300,330,300,330,300,330,300,330,300,120,90,330,120,120,300,330,300,330,90,120,300,330,300,330,120,120,300,330,90,120,300,120,90,330,300,330,120,120,300,330,90,120,300,330,330,330,300,330,90,120,300,330,300,330,300,120,90,330,300,120,90,120,120,330,300,120,90,330,300,120,120,330,300,120,120,120,90,120,120,120,90,120,90,330,90,120,300,120,120,330,90,120,90,120,90,120,90,120,300,120,90,120,90,120,120,120,90,120,90,120,90,120,120,120,90,330,90,120,90,120,90,120,90,120,90,120,90,120,300,120,120,330,330,330,300,330,300,120,90,330,300,360,60,120,300,330,90,120,300,330,120,120,300,330,90,120,300,120,120,330,300,330,300,330,300,330,300,330,120,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,120,120,90,120,300,330,90,120,300,330,90,120,300,330,90,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,90,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,300,120,90,120,90,120,90,120,90,120,90,120,90,330,120,120,300,330,300,330,300,330,90,120,300,330;
20;07;X2DDEBUG;81485200859022812093fc7aff
20;08;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=2093;S=2281;BAT=OK;
20;09;DEBUG;Pulses=511;Pulses(uSec)=210,90,330,300,120,90,120,90,120,90,120,90,120,90,330,120,120,300,120,90,330,120,120,90,120,120,120,90,120,300,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,120,330,120,90,120,120,90,120,90,120,90,120,90,120,300,120,120,330,300,330,300,330,300,120,90,330,300,330,120,120,300,330,90,120,300,330,90,120,300,330,90,120,300,120,90,330,300,330,330,330,300,330,300,330,90,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,120,120,90,120,300,330,90,120,300,330,90,120,300,330,90,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,120,120,90,120,90,120,90,120,90,120,90,120,90,120,90,120,300,120,120,120,90,120,90,120,90,120,90,120,120,330,90,120,300,330,300,330,300,330,90,120,300,330,300,120,90,330,300,120,90,330,300,120,90,330,300,120,90,330,90,120,300,330,300,330,300,330,300,330,300,120,90,330,120,120,300,330,300,330,120,120,300,330,300,330,90,120,300,330,90,120,330,120,90,330,300,330,90,120,300,330,90,120,300,330,300,330,300,330,90,120,300,330,300,330,300,120,90,330,300,120,90,120,90,330,300,120,90,330,300,120,90,330,300,120,90,120,90,120,90,120,90,120,90,330,90,120,330,120,90,330,120,120,90,120,90,120,90,120,300,120,90,120,90,120,120,120,90,120,90,120,90,120,90,120,120,330,90,120,120,120,90,120,120,120,90,120,90,120,300,120,90,330,300,330,300,330,300,120,90,330,300,330,120,120,300,330,90,120,300,330,90,120,300,330,90,120,300,120,90,330,300,330,300,330,300,330,300,330,90,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,330,120,90,330,300,120,90,330,300,330,300,330,330,120,90,330,330,330,330,330,90,120,300,330,90,120,90,120,300,330,90,120,330,330,90,120,300,330,120,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,120,120,90,120;
20;0A;DEBUG;Pulses=50;Pulses(uSec)=270,330,90,630,150,270,180,750,300,450,150,510,270,570,270,450,150,750,60,270,120,930,270,1470,90,150,210,1110,120,660,120,660,180,480,90,780,240,780,30,210,180,1020,270,720,150,660,60,840,60,6990;
Do you think there is a chance to get it working or not?20;0C;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1e2b;S=2281;BAT=OK;
20;0D;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c62a;S=2281;BAT=OK;
20;0E;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=69b0;S=2281;BAT=OK;
20;0F;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=f12b;S=2281;BAT=OK;
20;10;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1a2b;S=2281;BAT=OK;
20;11;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=08b0;S=2281;BAT=OK;
20;12;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=b692;S=2281;BAT=OK;
20;13;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c12a;S=2281;BAT=OK;
20;14;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=d092;S=2281;BAT=OK;
20;15;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=3692;S=2281;BAT=OK;
20;16;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c52a;S=2281;BAT=OK;
20;17;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=e92a;S=2281;BAT=OK;
20;18;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=09b0;S=2281;BAT=OK;
20;19;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=b392;S=2281;BAT=OK;
20;1A;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1c92;S=2281;BAT=OK;
20;1B;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1c2b;S=2281;BAT=OK;
20;1C;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=ce2b;S=2281;BAT=OK;
20;1D;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=d692;S=2281;BAT=OK;
20;1E;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=0393;S=2281;BAT=OK;
20;1F;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=3893;S=2281;BAT=OK;
20;20;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1493;S=2281;BAT=OK;
20;21;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=46b0;S=2281;BAT=OK;
20;22;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=8892;S=2281;BAT=OK;
In case you need additional logs tell me!
Many thanks in advance for your potential help (or not), I know X2D is tricky and that due to rolling code it might not be possible to make it working but I still have a little hope...
