Hi, I do not know why I have for the UV sensor on all frames one additional digit in front of the node number.
620;BF;Oregon UVN1x8;ID=EA10;UV=0006;BAT=LOW;
It is not always 6 I had also a 1
I'm forwarding the uart inputs using ser2net.
1003:raw:0:/dev/ttyACM0:57600 NONE 1STOPBIT 8DATABITS max-connections=3
I'm using the firmware:
20;EE;VER=1.1;REV=48;BUILD=04;
Additional digit in front of Oregon UVN1x8
Re: Additional digit in front of Oregon UVN1x8
same here
020;02;Oregon UVN1x8;ID=EA10;UV=0000;BAT=LOW;
220;75;Oregon UVN1x8;ID=EA10;UV=0002;BAT=LOW;
320;0B;Oregon UVN1x8;ID=EA10;UV=0003;BAT=LOW;
120;15;Oregon UVN1x8;ID=EA10;UV=0001;BAT=LOW;
As you can see, first digit is actual reading.
same here
