I realy need some help, I make a lot of research and test but I can't solve my problem.
I flash ESPeasy on a ESP8266 01. The flash is OK but when I reboot the esp and try to connect to his wifi, the esp seem to reboot non stop. I try many solution like change the firmware, use an older firware, an other flasher, use different power supply etc... I have always this boot loop, it's make me crazy.
In other hand, I flash Tasmota on the same module, and everything run perfectly.
I'm news to this module, and It's probably a sillymistake on my part.
Have you an idea to solve this problem ?
Setup I use :
ESP8226 01 https://www.amazon.fr/gp/product/B088LS ... UTF8&psc=1
ESPeasy firmware (last update) ESP_Easy_mega_20220427_normal_ESP8266_1M.bin and trying a lot other
ESP.Easy.Flasher and NODEMCU Pyflasher
And this serial monitor when ESP8266 boot with ESP_Easy_mega_20220427_normal_ESP8266_1M.bin
rl lÉr☻$↕Ôn♀♀♀─♀lÃ♀b|ÄÉ☻↕Ær↕b─♀b♦‗nn☻lnn2b♀b∟pý$b♫lrlp‗n0☻♀♀É♀l♀î☻♀♀♀b♀n┬nÃl♦♀♦b─‗nn'lî♦l`☻É↕↕no♀l`☻♫☻nrÄÆÆn♀♀b☻l`☻♫rÆÆn♀♀b☻l`☻£b♀♀ÄlÆlrÆ`☻³énbÓ¬U81 : Info : WIFI : Set WiFi to OFF
199 : Info :
INIT : Booting version: mega-20220427 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
200 : Info : INIT : Free RAM:31360
201 : Info : INIT : Cold Boot - Restart Reason: External System
202 : Info : FS : Mounting...
208 : Info : FS : Mount successful, used 1506 bytes of 113201
RESET: Resetting factory defaults... using default settings
RESET: Warm boot, reset count: 0
RESET: formatting...
RESET: formatting done...
1761 : Error : FS : Error while reading/writing config.dat in 3055
1848 : Error : FS : Error while reading/writing security.dat in 3055
1935 : Error : FS : Error while reading/writing notification.dat in 3055
2048 : Error : FS : Error while reading/writing config.dat in 3055
2051 : Error : FS : Error while reading/writing config.dat in 3131
2092 : Error : FS : Error while reading/writing config.dat in 3138
2139 : Error : FS : Error while reading/writing security.dat in 3138
2143 : Error : FS : Error while reading/writing security.dat in 3131
RESET: Successful, rebooting. (you might need to press the reset button if you've just flashed the firmware)
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
¬U193 : Info : WIFI : Set WiFi to OFF
311 : Info :
312 : Info : INIT : Free RAM:31360
313 : Info : INIT : Soft Reboot #1 - Restart Reason: Software/System restart
314 : Info : FS : Mounting...
320 : Info : FS : Mount successful, used 1506 bytes of 113201
RESET: Warm boot, reset count: 1
1873 : Error : FS : Error while reading/writing config.dat in 3055
1960 : Error : FS : Error while reading/writing security.dat in 3055
2047 : Error : FS : Error while reading/writing notification.dat in 3055
2160 : Error : FS : Error while reading/writing config.dat in 3055
2163 : Error : FS : Error while reading/writing config.dat in 3131
2204 : Error : FS : Error while reading/writing config.dat in 3138
2251 : Error : FS : Error while reading/writing security.dat in 3138
2255 : Error : FS : Error while reading/writing security.dat in 3131
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
¬U191 : Info : WIFI : Set WiFi to OFF
309 : Info :
310 : Info : INIT : Free RAM:31360
311 : Info : INIT : Soft Reboot #2 - Restart Reason: Software/System restart
312 : Info : FS : Mounting...
318 : Info : FS : Mount successful, used 1506 bytes of 113201
RESET: Warm boot, reset count: 2
1870 : Error : FS : Error while reading/writing config.dat in 3055
1957 : Error : FS : Error while reading/writing security.dat in 3055
2044 : Error : FS : Error while reading/writing notification.dat in 3055
2157 : Error : FS : Error while reading/writing config.dat in 3055
2161 : Error : FS : Error while reading/writing config.dat in 3131
2201 : Error : FS : Error while reading/writing config.dat in 3138
2248 : Error : FS : Error while reading/writing security.dat in 3138
2252 : Error : FS : Error while reading/writing security.dat in 3131
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
¬U192 : Info : WIFI : Set WiFi to OFF
310 : Info :
311 : Info : INIT : Free RAM:31360
312 : Info : INIT : Soft Reboot #3 - Restart Reason: Software/System restart
RESET: Warm boot, reset count: 3
RESET: Too many resets, protecting your flash memory (powercycle to solve this)
1329 : Error : FS : Error while reading/writing config.dat in 3264
1331 : Error : FS : Error while reading/writing security.dat in 3266
1332 : Error : CRC : SecuritySettings CRC ...FAIL
1333 : Error : FS : Error while reading/writing security.dat in 3265
1335 : Info : INIT : I2C
1336 : Info : INIT : SPI not enabled
1337 : Info : Time set to 3.000 Time adjusted by 1663.00 msec. Wander: 0.000 msec/second Source: RTC at boot
1339 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
1341 : Info : Local time: 1970-01-01 00:00:03
1343 : Info : WiFi : Start network scan all channels
3530 : Info : WiFi : Scan finished, found: 3
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (0):
epc1=0x4000e25d epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3fff24b0 end: 3fff2750 offset: 0190
3fff2640: 402c980a 3fff1374 3ffefdc8 3fff00e8
3fff2650: 40273352 00000000 3fff4544 40273459
3fff2660: 0000001c 00000000 00000000 00000000
3fff2670: 00000003 00000000 3fff4394 4027368e
3fff2680: 3fff1618 00000001 3fff1618 3fff00e8
3fff2690: 00000000 00000001 3fff1618 4026d7fc
3fff26a0: 00000000 3fff1618 0000000a 402731f2
3fff26b0: 00000000 0000001c 00000000 4026d774
3fff26c0: 3fff1618 3fff01e0 00000000 4023bb24
3fff26d0: 3fff13f8 3fff1374 3fff01e0 4023b912
3fff26e0: 3fff0000 0017001f 80efeffe 402c0000
3fff26f0: 00000000 80ff1618 feefeffe feefeffe
3fff2700: 00000000 feefeffe feefeffe feefeffe
3fff2710: feefeffe feefeffe feefeffe 3fff279c
3fff2720: 3fffdad0 00000000 3fff2758 4020e7b8
3fff2730: feefeffe feefeffe feefeffe 40270733
3fff2740: feefeffe feefeffe 3ffe86cc 40100651
<<<stack<<<
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
311 : Info :
313 : Info : INIT : Exception #4 - Restart Reason: Exception
1330 : Error : FS : Error while reading/writing config.dat in 3264
1332 : Error : FS : Error while reading/writing security.dat in 3266
1333 : Error : CRC : SecuritySettings CRC ...FAIL
1334 : Error : FS : Error while reading/writing security.dat in 3265
1336 : Info : INIT : I2C
1337 : Info : INIT : SPI not enabled
1339 : Info : Time set to 3.000 Time adjusted by 1662.00 msec. Wander: 0.000 msec/second Source: RTC at boot
1340 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
1342 : Info : Local time: 1970-01-01 00:00:03
1344 : Info : WiFi : Start network scan all channels
3532 : Info : WiFi : Scan finished, found: 5
3535 : Error : W
Exception (0):
>>>stack>>>
ctx: cont
3fff2650: 40273352 00000000 3fff320c 40273459
3fff26e0: 65630000 6f697470 80ef006e 402c0000
<<<stack<<<
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
309 : Info :
311 : Info : INIT : Exception #5 - Restart Reason: Exception
311 : Info : FS : Mounting...
317 : Info : FS : Mount successful, used 1506 bytes of 113201
1328 : Error : FS : Error while reading/writing config.dat in 3264
1330 : Erro
