Bug Report V101, autoconfig
BerndJ
#1 Post by BerndJ » 17 Apr 2016, 16:01
i take V101 on an resetted ESP-01 and tested the autoconfig:
see ESP_0 on my iPhone
login to these AP
set the WLAN Parameters,
see in the serial line, he´s logging in
get an IP via DHCP (another IP Range, outside the old one)
INIT : Boot OK
INIT : Normal boot
>settings
System Info
IP Address : 0.0.0.0
Build : 101
Unit : 0
WifiSSID : ssid
WifiKey : wpakey
Free mem : 26072
Ok
WD : Uptime 0 ConnectFailures 0 FreeMem 26200
add 1
aid 1
station: 90:b9:31:09:3c:87 join, AID = 1
WD : Uptime 1 ConnectFailures 0 FreeMem 25056
scandone
WD : Uptime 1 ConnectFailures 0 FreeMem 24256
WIFI : Connecting... 1
scandone
state: 0 -> 2 (b0)
station: 90:b9:31:09:3c:87 leave, AID = 1
rm 1
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with xxxxxx, channel 2
dhcp client start...
ip:192.168.113.239,mask:255.255.255.0,gw:192.168.113.1
WIFI : Connected!
after that i did´nt can´t access this site, there´s an redirect to:
192.168.4.1/setup
and this is outside the possible range.
settings
System Info
IP Address : 192.168.113.239
Build : 101
Unit : 0
WifiSSID : xxxxxx
WifiKey : xxxxxxxxxxxxxxxxx
Free mem : 24136
Ok
I did´nt see any "FLASH: Settings saved" on the serial line.
a week ago i wrote a bug report regarding ESP-12F, see
http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1368
it looks like the same problem.
PS:
found a workaround until these problem is solved:
call:
this is running fine
click on the "submit" Button
u can see in the serial line:
what is NOT Running:
after that change to "Tools" and press the reboot button.
This runs:
Press the resetbutton on the hardware
or repower it.
AFTER this INIT u can use your ESPeasy on the normal way
petrho
Re: Bug Report V101, autoconfig
#2 Post by petrho » 17 Apr 2016, 22:33
same problem! tested both R100 and R101
timsson
#3 Post by timsson » 18 Apr 2016, 20:26
yes, same problem!
Martinus
#4 Post by Martinus » 19 Apr 2016, 14:18
The initial Wifi setup should take you to the config page as the last step, there you should submit the main config settings and they should be saved to flash.
As described here on the Wiki page: http://www.esp8266.nu/index.php/EasySetup
Did you reconnect the iPhone to your primary AP during the process, before clicking "Proceed to main config" ?
BerndJ
#5 Post by BerndJ » 19 Apr 2016, 22:09
Martinus wrote:.... before clicking "Proceed to main config" ?
Hi Martinus,
i´d never see this point.
In the first step i give him the WLAN Parameters and click connect.
2nd my iPhone looses the ESP_0 AP and connect into my WLAN, automaticcally, no chance to change this.
the following redirect is wrong, but only when u ask without suffix: 192.168.4.1 because the new DHCP Address is there ignored.
clicking "Proceed to main config"......., never seen.
So, just testet again:
iphone looses ESP_0 AP
taked a look with my wifi card on the PC, oh !! it´s exist´s!
connect and taked a look into 192.168.4.1
there are your site, nice,
clicked on "Proceed to main config" and seen in the serial line: nothing happens
but i´m in the config tab in the browser, click on submit and now the settings are saved!
So we had a problem on the way
