Image File for ESP8266?
davidgbal
#1 Post by davidgbal » 14 Nov 2022, 00:25
I used ESPEasy a little while ago with ESP8266. The image file I used was this one ESP_Easy_mega_20210114_normal_EPS8266_1M.bin but I can't see a similar one with the latest build. Thsi is the closest image I can see ESP_Easy_mega_20221105_minimal_IRext_ESP8266_1M.bin.
I can connect to the ESP8266 with AP EASY-ESP and password configesp, but when I try to connect to the webpage with the reported IP address in the serial monitor I get the following error:
1045672 : Info : WD : Uptime 16 ConnectFailures 0 FreeMem 23104 WiFiStatus 0 ESPeasy internal wifi status: DISCONNECTED
1048887 : Error : serveEmbedded failed: esp.css
Any ideas?
Regards,
David
Re: Image File for ESP8266?
#2 Post by TD-er » 14 Nov 2022, 00:49
Could be the CDN server I listed in that build is no longer serving these "old" files.
I guess we should make one CDN server ourselves and/or make the URL for the CDN server configurable.
davidgbal
#3 Post by davidgbal » 14 Nov 2022, 13:45
Is there a link available to the older images?
On the issue serving the webpage, it seems that it is slower than expected.... the home page had in fact appeared on my ipad when I looked later.
Regards,
David
#4 Post by TD-er » 14 Nov 2022, 13:47
Here are all the builds from the past 5+ years: https://github.com/letscontrolit/ESPEasy/releases
davidgbal
#5 Post by davidgbal » 14 Nov 2022, 14:37
Great... I will take a look.
Thank you for your time.
Regards,
David
davidgbal
#6 Post by davidgbal » 14 Nov 2022, 18:16
The files stopped after Dec 2021. I have them now and all is working fine.
Regards,
David
Users browsing this forum: Ahrefs [Bot] and 19 guests
