No ESP32 IR ETH ?
iron
No ESP32 IR ETH ?
#1 Post by iron » 26 Dec 2022, 12:44
Seems like there is no ESP32 IR ETH build in the binaries ?
My Olimex ESP32-EVB have both Rx and Tx IR along with ETH
-D
Re: No ESP32 IR ETH ?
#2 Post by TD-er » 26 Dec 2022, 12:52
Just to be sure, it is a 4M unit?
iron
#3 Post by iron » 26 Dec 2022, 13:19
TD-er wrote: 26 Dec 2022, 12:52 Just to be sure, it is a 4M unit?
ESP Chip Model: ESP32-D0WDQ5-V3
ESP Chip Revision: 3
ESP Chip Cores: 2
ESP Board Name: Espressif Generic ESP32 4M Flash ESPEasy 1810k Code/OTA 316k FS
Now on
ESP_Easy_mega_20221224_normal_ESP32_4M316k_ETH
-D
#4 Post by TD-er » 26 Dec 2022, 13:23
On that same page you can also see the detected flash size.
#5 Post by Ath » 26 Dec 2022, 13:25
A few lines below that info there is the "Flash Chip Real Size" value, does that also show 4096 kB or 16384 kB?
iron
#6 Post by iron » 26 Dec 2022, 13:26
TD-er wrote: 26 Dec 2022, 13:23 On that same page you can also see the detected flash size.
Flash Chip ID: Vendor: 0x5E Device: 0x4016
Flash Chip Real Size: 4096 kB
-D
#7 Post by Ath » 27 Dec 2022, 14:29
I've create Pull request #4437 to add 1 Normal and 2 Custom builds that include both IR and Ethernet.
Users browsing this forum: Ahrefs [Bot] and 19 guests
