Custom.h include problem
I am trying to compile FW for SonOff based on 8285/1M with own set of sensors/defaults.
Environment of compilation - Linux Mageia 8, Code + Platformio. All up-to-date.
In ESPEasy-mega-20221224, I don't see any option to select 8285 processor in Platformio. There is only ready FW binary for 8185.
Perhaps I am doing something wrong - please advise.
So I try with ESPEasy_ESP82xx_mega-20211224. It compiles but doesn't take into account my Custom.h file.
I've been using this file for 3 years and it's always been OK.
Does not help Platfornio console command -> export PLATFORMIO_BUILD_FLAGS="'-DUSE_CUSTOM_H'"
I would like some advice on what I am doing wrong.
Re: Custom.h include problem
Form VSCode you can select one of the Custom environments (probably custom_ESP8266_1M) to build that set. As described in the Developers guide
For running on an ESP8285 you can use the ESP8266 build, it will auto-detect it is running on an ESP8285, and act accordingly.
Does ESPEasy-mega-20221224 really support ESP8285? I am not sure.
As long as you take a PlatformIO env for 1M ESP8266, then it should work.
THX for answers. Will try when will be back home weekend.
I will forward the results
Just curious, as there do exist 2M ESP8285 modules...
Is this a rather new unit? And if so, can you check the sysinfo page to see what (real) flash size is detected?
Also, does it properly report an ESP8285?
Is this a new module - I don't know. I just bought the SonOff Dual that was in the store.
Below is a copy/paste of the entire "Main" menu.
As you can see the processor is detected correctly.
Unit Number: 0
Local Time: 2023-02-09 08:55:05
Time Source: NTP
Time Wander: -7.0 [ppm]
Uptime: 0 days 2 hours 24 minutes
Load: 6.00% (LC=10248)
CPU Eco Mode: false
Boot: Cold Boot (0)
Reset Reason: Power On
Last Action before Reboot: Background Task
SW WD count: 0
Memory
Free RAM: 19664
Free Stack: 3760
Network
IP Config: Static
IP / Subnet: 192.168.0.17 / 255.255.255.0
Gateway: 192.168.0.1
Client IP: 192.168.0.2
DNS: 192.168.0.201 / (IP unset)
Allowed IP Range: 192.168.0.0 - 192.168.0.255
Connected: 44 m 16 s
Number Reconnects: 2
WiFi ?
WiFi Connection: 802.11g (RSSI -62 dBm)
SSID: MyWiFi (54:A0:50:CC:BF:02)
Channel: 8
Encryption Type: WPA/WPA2/PSK
Last Disconnect Reason: (8)
Configured SSID1: MyWiFi
Configured SSID2: Test-WiFi
STA MAC: 70:03:9F:5C:1F:41
AP MAC: 72:03:9F:5C:1F:41
WiFi Settings
Force WiFi B/G: false
Restart WiFi Lost Conn: true
Force WiFi No Sleep: true
Periodical send Gratuitous ARP: true
Connection Failure Threshold: 0
Max WiFi TX Power: 17.50
Current WiFi TX Power: 9.00
WiFi Sensitivity Margin: 3
Send With Max TX Power: false
Extra WiFi scan loops: 0
Use Last Connected AP from RTC: false
Firmware
Build:⋄ 20230207 - Mega
System Libraries:⋄ ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄ Test-5: Feb 7 2023 08:37:44
Plugin Count:⋄ 33 [No Debug Log]
Build Origin: Self built
Build Time:⋄ Feb 7 2023 08:37:41
Binary Filename:⋄ ESP_Easy_mega_20230207_custom_ESP8266_1M
Build Platform:⋄ Linux-5.15.88-desktop-1.mga8-x86_64-with-glibc2.2.5
Git HEAD:⋄ pygit2_not_installed
System Status
Syslog Log Level: None
Serial Log Level: None
Web Log Level: None
I2C Bus State: OK
I2C bus cleared count: 0
Network Services
Network Connected: ✔
NTP Initialized: ✔
ESP Board
ESP Chip ID: 6037313 (0x5C1F41)
ESP Chip Frequency: 80 MHz
ESP Chip Model: ESP8285
ESP Chip Cores: 1
ESP Board Name: Espressif Generic ESP8266 ESPEasy 1M Flash 128k FS
Storage
Flash Chip ID: Vendor: 0x51 Device: 0x4014
Flash Chip Real Size: 1024 kB
Flash IDE Size: 1024 kB
Flash Chip Speed: 40 MHz
Flash IDE Speed: 40 MHz
Flash IDE Mode: DOUT
Flash Writes: 0 daily / 0 boot
Sketch Size: 770 kB (104 kB free)
Max. OTA Sketch Size: 599 kB (614384 bytes)
OTA possible: false
OTA 2-step Needed: true
SPIFFS Size: 110 kB (54 kB free)
Is indeed reporting it as an ESP8285 and 1M flash.
I was just wondering whether those 2M ESP8285 actually do exist in the wild, as I only "know" about their existence from the Espressif datasheets.
I've some in my Athom PG01V2:
ESP Board
ESP Chip ID: 15811792 (0xF144D0)
ESP Chip Cores: 1
ESP Board Name: Espressif Generic ESP8266 ESPEasy 2M Flash 256k FS
Storage
Flash Chip ID: Vendor: 0xA1 Device: 0x4015
Flash Chip Real Size: 2048 kB
Flash IDE Size: 2048 kB
Flash Writes: 4 daily / 4 boot
Sketch Size: 715 kB (1076 kB free)
Max. OTA Sketch Size: 1019 kB (1044464 bytes)
OTA possible: true
OTA 2-step Needed: false
SPIFFS Size: 209 kB (126 kB free)
Page size: 256
Block size: 4096
Number of blocks: 52
Maximum open files: 5
Maximum path length: 32
ESP Board
ESP Chip Cores: 1
Storage
OTA possible: true
Page size: 256
Block size: 4096
Ah, good to know they really do exist
Users browsing this forum: Bing [Bot] and 15 guests
