L293D (DollaTech) Motor Drive + ESP8266 ESP12E
Riewekooche
#1 Post by Riewekooche » 17 Feb 2023, 13:00
Hi there,
working on a project which controls a DC motor and a DC valve i would like to use the motorshield with the L293D.
This is a little board into which i stack the ESP12E.
The ESP12E works fine.
But I miss a device to control the L293D. https://www.ebay.de/itm/162774530925?var=461812461596
If there isn't one, how can i control the L293D by the GPIO-pins manually?
And is there a driver for the Sparfun Qwiic Micropressure sensor? https://www.ebay.de/itm/164220619141
Re: L293D (DollaTech) Motor Drive + ESP8266 ESP12E
#2 Post by Ath » 17 Feb 2023, 17:14
Riewekooche wrote: 17 Feb 2023, 13:00 working on a project which controls a DC motor and a DC valve i would like to use the motorshield with the L293D.
We only have support for the Wemos and Lolin motor controllers, but AFAICS, that's not using that L293D chip, so most likely that won't work.
Riewekooche wrote: 17 Feb 2023, 13:00 And is there a driver for the Sparfun Qwiic Micropressure sensor? https://www.ebay.de/itm/164220619141
There is a new PR #4490 opened recently that adds support for such Honeywell pressure sensor, you could get a PR build from Github to test that.
#3 Post by TD-er » 17 Feb 2023, 17:16
I did have a (very) quick look at the datasheet of the chip, and it seems like it is a very simple H-bridge.
So you could have a look at the PWM motor plugin.
#4 Post by TD-er » 17 Feb 2023, 17:20
I don't think the pressure sensor linked by Ath will work with that plugin as it seems like the one on ebay is using some HX710 chip, which is probably a bit like the HX711 used in scales to measure weight.
The Honeywell pressure sensors send out a raw ADC value and temperature via I2C and if this HX710 is a bit like the HX711, then it is probably using a rather basic protocol, not I2C.
#5 Post by Ath » 17 Feb 2023, 21:51
For the pressure sensor I searched for the name given, the Sparkfun one and that's an I2C sensor, but that's indeed not the (much) cheaper clone that's linked.
Did find 2 interesting sources for this HX710x ADC:
- https://swharden.com/blog/2022-11-14-hx710b-arduino/
- https://www.electroschematics.com/press ... sor-guide/
The protocol is indeed quite similar to the HX711 as available in P067, but I don't think it's sensible to try and add this sensor there, as it already has quite a few options.
Just for fun you could try to connect it to the HX711 P067 plugin, and see if it returns somewhat sensible values. If it does, that's great, but I wouldn't expect too much of it.
Riewekooche
#6 Post by Riewekooche » 20 Feb 2023, 09:38
I tried to read the pressure sensor with its TM7711 chip by the HX711 device - and it works !! :D
It doesn't use a I2C interface. Only a Data/SCLK 2-wire protocol.
The problem with the motor shield for the ESP12E was my fault with a rule.
Now it works :D
bidrohini
#7 Post by bidrohini » 20 Feb 2023, 09:53
Here is an old thread about Firmware Support for L298H Bridge Boards. This may help you a bit.
https://www.letscontrolit.com/forum/vie ... f=5&t=8809
Users browsing this forum: Anthropic Claude Bot [bot] and 32 guests
