on Clock#Time=All,**:00 do
- Andrew Mamohin
How can I make an event that runs every hour at exactly 0 minutes?
If I put "on Clock#Time=All,**:00 do", then it throws an error: "timeStringToSeconds: '0' --> invalid".
The same happens if "Clock#Time=All,**:0".
If I put "on Clock#Time=All,**:01 do", then everything turns out well.
Andy.
Re: on Clock#Time=All,**:00 do
Sounds like a bug....
As a work-around, you could start a timer at :59 and act on the event triggered by this timer.
Just until this bug is fixed. (Related GitHub issue)
- Andrew Mamohin
Thanks for the answer! For now, I'll set the event to 01, it's not so critical. I just wanted to show a bug.
Andy.
I just looked into this and I find it really strange this error is occuring now.
The only changes made to it (2 years ago) is to change `byte` to `uint8_t`
The latest change before that was 3 year ago.
Hmm, looks like the getNumerical function is acting up here....
May have to look at it later this evening.
Can you test the test build for this PR (when it is ready) ?
https://github.com/letscontrolit/ESPEasy/pull/4573
- Andrew Mamohin
- Andrew Mamohin
Great!
This was a bug in our numerical parser function, so it may also fix other issues where numbers are parsed.
The fixes have been merged into 'mega'.
Users browsing this forum: Bing [Bot] and 8 guests
