Wimos and FS300A
tocks
Wimos and FS300A
#1 Post by tocks » 27 Apr 2016, 09:30
I am newbee on ESPEasy, I just bought 2 mini Wemos.
I wonder if it is compatible with a FS300A?
http://fr.aliexpress.com/item/Free-Ship ... 42021.html
thanks a lot
costo
Re: Wimos and FS300A
#2 Post by costo » 27 Apr 2016, 15:09
The hall sensor needs a voltage between 4.5 and 20 volt to work properly. When powered with 5 volt it will give output pulses of 5 volt. That is not compatible with any ESP8266. You have to use a voltage divider or level converter between the yellow output pin to the FS300A and the ESP.
tocks
#3 Post by tocks » 28 Apr 2016, 19:45
hello, thanks for your reply.
But i don't understand. Why i do use a voltage divider or level converter ?
The wemos has a pin 5 V, it's not good for this sensor ?
andy
#4 Post by andy » 28 Apr 2016, 20:42
GPIO inputs are 3.3V max, except Tout, or ADO, which is 1V max.
tocks
#5 Post by tocks » 29 Apr 2016, 11:27
ok so I understand:
I can supply the FS300A with Wemos in 5v.
But the input pin can only support 3.3V Max. So I have to put a converter for 3.3V max . Tell me if I misunderstood
Can you recommend a converter that I can find on eBay or Alibaba to put between the input pin and the yellow cable of the sensor?
costo
#6 Post by costo » 30 Apr 2016, 11:42
Just use a resistive divider to drop down the 5v output of the sensor to 3.3 volt.
You can take 3 resistors of equal value, (between 1k and 5k each) connect the resistors in series from the sensor output to ground.
You will have 1/3 of the output at the resistor closest to ground and 2/3 of the output value at the other point, that point can be connected to a ESP GPIO input.
tocks
#7 Post by tocks » 30 Apr 2016, 13:05
Can you post me a schema of the divisor ?
I have found this : http://fr.aliexpress.com/item/4-channel ... .18.i3mqq8
This module does it work?
if not, I have this module in my stock :
I can use in my case?
costo
#8 Post by costo » 30 Apr 2016, 14:46
Sure that module of your aliexpress link will do the job.
But using a few resistors will work in this particular case as good because you dropdown the voltage.
Resistors are probably more easy to get. (some people stockpile them) :D
explanation:
https://en.wikipedia.org/wiki/Voltage_divider
Vin is your sensor output FS300A
Vout to the GPIO of the ESP where you count the pulses
GND common ground for all of the circuits.
Z2 is twice the value of Z1
If Z1 = 1k-ohm then Z2 = 2k-ohm
or
Z1 = 4k7 and Z2 = 10K That is exact enough.
tocks
#9 Post by tocks » 30 Apr 2016, 16:12
thanks for your explanation.
I have in stock 10k, but not 4.7K. I can buy it.
but if :
Vin is your sensor output FS300A : 5V
Vout to the GPIO of the ESP where you count the pulses 3.3V
Vout = (R2/(R1+R2))*Vin
Vout = (10/(10+4.7))*5
Vout = (10/14.7)*5
Vout = 0,680272109 *5
Vout = 3,401360544
the result is > 3.3V, it's not a problem ?
I have a another project with PH sensor on wemos, the output is analogic with 5V. I can use the same ?
Thanks a lot
costo
#10 Post by costo » 30 Apr 2016, 16:30
If you have enough 10k in stock you can use 2 * 10k in parrallel instead of 4k7.
A difference of a few tenths of a volt is usually no problem
tocks
#11 Post by tocks » 30 Apr 2016, 16:49
thanks, but i don't understand .
I can replace 4K7 with 2*10K ?
Z1 = 2*10K and Z2 = 10K
Vout = (10/(10+20))*5
Vout = (10/30)*5
Vout = 0,333333333 *5
Vout = 1,666666665
My Vout is not good .
costo
#12 Post by costo » 30 Apr 2016, 16:59
tocks wrote:thanks, but i don't understand .
You don't know what parrallel is ?
tocks
#13 Post by tocks » 30 Apr 2016, 17:47
Ho, sorry. I understand.
Can you confirm my schema ?
costo
#14 Post by costo » 30 Apr 2016, 21:56
Do the calculation yourself please.
Users browsing this forum: Bing [Bot] and 27 guests
