I have a string variable like '1356' or '246' (interpret sprinkling areas) from which I want to process all single digits in a rule with the substring-command.
Is there any possibility to determine the end of the string, like StringLen() or something similar?
StringLen in rules ?
Re: StringLen in rules ?
You could assign it to a variable and thus turn it into a numerical.
Then just divide it by 10 and check if its [int#N] representation is still > 0.
Not optimal/pretty, but could work. Good that the segments start with 1 for me
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
