wiredcharlie
#1
Post
by wiredcharlie » 18 Jul 2023, 18:20
I have a physical toggle switch as an input. I want to be able to read the sate of the switch onboot.
Experiment:
On System#Boot do
If Pump#State=1
7dtext,On
Endif
If Pump#State=0
7dtext,Off
Endif
No output! The switch has no state until it reveals itself by changing state?
Micha_he
#2
Post
by Micha_he » 18 Jul 2023, 20:55
Have you enabled "Send boot state" in the switch-configuration?
#3
Post
by Ath » 18 Jul 2023, 20:56
wiredcharlie wrote: ↑18 Jul 2023, 18:20
It is not sure that the Switch plugin or 7Segment plugin are already initialized at the System#Boot event, so you might want to wait a little, for an event that will occur a bit later:
On WiFi#Connected do
If Pump#State=1
7dtext,On
Else
7dtext,Off
Endif
Also simplified the code a bit, using 'else' instead of another 'if'.
wiredcharlie
#4
Post
by wiredcharlie » 18 Jul 2023, 21:20
Micha_he wrote: ↑18 Jul 2023, 20:55
Tried that - but thanks
Ath wrote: ↑18 Jul 2023, 20:56
...but I had it displaying something else from On boot and it worked.
for an event that will occur a bit later:....
... I tried a one second delay with a timer but that didn't work.
I think most folk use buttons, but this use case relies upon a pre-select, where the switch is set and then the power is switched on.
chromo23
#5
Post
by chromo23 » 18 Jul 2023, 21:52
Have you tried TaskRun?
On System#Boot do
TaskRun,1 //(or whatever the number of the switch plugin is)
On Pump#State do
If %eventvalue%=1
7dtext,On
Else
7dtext,Off
Endif
#6
Post
by Ath » 18 Jul 2023, 21:59
chromo23 wrote: ↑18 Jul 2023, 21:52
On System#Boot do
You mean TaskRun,Pump ?
chromo23
#7
Post
by chromo23 » 18 Jul 2023, 22:02
Ath wrote: ↑18 Jul 2023, 21:59
Wow, is this a thing now?
Things are changing fast here....
#8
Post
by Ath » 18 Jul 2023, 22:07
chromo23 wrote: ↑18 Jul 2023, 22:02
That improvement was
merged well over 2 years ago
chromo23
#9
Post
by chromo23 » 18 Jul 2023, 22:12
Ath wrote: ↑18 Jul 2023, 22:07
wiredcharlie
#11
Post
by wiredcharlie » 19 Jul 2023, 12:26
Thanks TD-er!
That was really helpful. Also, by triggering the Monitor instruction after boot, I removed the unintended consequence of pre-setting the switch prior to power on.
