MQTT sends only Value of Sensor - no Topic
stanus74
#1 Post by stanus74 » 16 Aug 2023, 17:09
I am a new user of ESPEasy.
I use Home Assistant with MQTT Broker. Zigbee2Mqtt works with the broker.
Now I want to use the DHT11 sensor with ESP8266.
The values of the sensor are displayed under Device.
I have set "Send to Controller" to Enable.
However, the controller only sends the sensor values without setting the topic in front.
MQTT Settings:
Here is a log from the MQTT Broker:
{"battery":100,"illuminance":27458,"illuminance_lux":557,"led_indication":null,"linkquality":0,"motion_sensitivity":"low","occupancy":false,"occupancy_timeout":0,"temperature":25.11}
27.30
73.50
{"Time":"2023-08-16T15:55:40","Uptime":"0T00:11:11","UptimeSec":671,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Garten_Fritz","BSSId":"3C:37:12:1E:E0:17","Channel":3,"Mode":"11n","RSSI":50,"Signal":-75,"LinkCount":1,"Downtime":"0T00:00:06"}}
27.30
73.50
27.30
73.50
Using version mega-20230623 on a Wemos D1.
Thank you
Re: MQTT sends only Value of Sensor - no Topic
#2 Post by TD-er » 16 Aug 2023, 17:38
How do you look at these published messages on the MQTT broker?
Can you have a look at tools like MQTT explorer?
This tool gives a lot more insight in what is happening.
As you can see in the controller settings, there is a number of system variables being used to create the topic to which the message is published.
So make sure you have a sysname set in ESPEasy and the task for your DHT sensor does have a unique name and set a task value name.
So the topic should be something like "ESPEasy/DHT/temp", assuming your node is called "ESPEasy", the task is called "DHT" and the task value name is "temp".
#3 Post by Ath » 26 Aug 2023, 21:58
stanus74 wrote: 16 Aug 2023, 17:09 Hello,
MQTT Settings:
27.30
73.50
27.30
73.50
27.30
73.50
Thank you
I just now see that the Controller Publish field has an error. "%sysname%/%tskname%/%valname'" should be "%sysname%/%tskname%/%valname%", so for some reason the last percent sign was replaced by a single quote. If you fix that, it should work as intended :o
Users browsing this forum: Ahrefs [Bot] and 4 guests
