i have a Stepper driver 4Ampere with puls and dir pin.
How can I control this amplifier with esp easy.
Best regards
Oliver
Stepper Control
Re: Stepper Control
Depends on what you want to do.
Using longpulse_ms, you could already do really basic operations on the stepper motor.
See:
https://espeasy.readthedocs.io/en/lates ... ernal-gpio
For example use this in the rules: (replace 'X' with the GPIO you need for the direction, replace 'Y' with the GPIO for the pulses)
Then you can trigger an event like this, to make 1000 steps in the "up" direction:
event,stepup=1000
100 steps down:
event,stepdown=100
See:
on stepup do
gpio,X,1
longpulse_ms,Y,1,10,10,%eventvalue1%
on stepdown do
gpio,X,0
event,stepup=1000
100 steps down:
event,stepdown=100
Re: Stepper Control
thank you for your Answer.
I would like to control a stepper motor as a suntracker.
In the morning, approach limit switch 1 east. At midday, approach limit switch 2, south. In the evening, approach limit switch 3 west. Sunset back to the east.
Thank you
Oliver
Thank you
Oliver
Re: Stepper Control
How many steps does it roughly take between each limit switch?
Also what would be the best approach for your setup?
Divide the time between sunrise and noon in N pulses, or let it run a few pulses every minute (or 5 minutes), so it can overcome some friction to start moving.
Re: Stepper Control
I'll try that out. I want to control via http request
In node red you have all expansion options.
With this command in the Browser or Node red, rotate the stepper left or right .
http://192.168.178.121/control?cmd=event,stepup.
http://192.168.178.121/control?cmd=event,stepdown
rule1
on stepup do
gpio,26,1
longpulse_ms,25,1,10,10,500
rule2
on stepdown do
gpio,26,0
Best regards
Oliver
rule1
on stepup do
gpio,26,1
rule2
on stepdown do
gpio,26,0
Best regards
Oliver
Re: Stepper Control
For maintenance it is much easier to have those rules in a single rules file, no need to store them in separate files, as they are handled sequentially. The split was once, a long time ago, needed because of the way the rules files were then uploaded, but that has been resolved years ago.
Users browsing this forum: Ahrefs [Bot] and 13 guests
