Calculate with data from 2 different sensor
Cover1987
#1 Post by Cover1987 » 17 Oct 2023, 23:33
Hi guys,
i'm struggling with some rules.
I try to calculate the solved CO2 in a liquid with an Pressure sensor (12MPa sensor as internal imput) and the temperature (bme280) - and show it on an OLEd display (thats not the problem).
The sensors are working and i read the rules manual... but i cant find a solution.
i have the formula:
co2 = (pressure[bar] + 1,013) * (2,71828182845904^(-10,73797 + (2617,25/(Temperatur[°C] + 273,15)))) * 10
I guess i need a new variable (co2) but it can't be an uint32_t. Can i use another type of var?
I Tried to start with something like
on BME#Temp do
   logentry,"Aenderung Temp: [BME#Temp] "
   <here should be the the definition of the variable and the calculation>
on Drucksensor#Druck do
   logentry,"Aenderung Druck: [Drucksensor#Druck]"
Everytime when 1 of the 2 sensor values is changing the formula should be newly calculated (and showed on the OLED)
Can anyone help me with it?
Re: Calculate with data from 2 different sensor
#2 Post by TD-er » 18 Oct 2023, 00:11
On each update of either value, you should generate an event (preferrably an async event)
This way you only need to have the computational code only once.
Internal variables in rules (those in memory, thus lost after a reboot) are of type double (in C++)
So I doubt you need to store it as an uint32 to keep resolution.
on BME#Temp do
   asyncevent,ComputeCO2
on ComputeCO2 do
  // Split this into several steps
  // let,1,(2617.25/([BME#Temp] + 273.15))-10.73797
  let,1,[BME#Temp]+273.15  // To Kelvin
  let,1,2617.25/[var#1]
  let,1,[var#1]-10.73797
  let,1,2.71828182845904^[var#1]
  let,1,10*[var#1]
  let,2,[Drucksensor#Druck]+1.013
  let,1,[var#2]*[var#1]  // [var#1] is final CO2 value
Cover1987
#3 Post by Cover1987 » 18 Oct 2023, 00:56
Oh wow, that was fast! Thank you very very much!
(There was only on typo in the last line that i could figure out thanks to the great comments ;) there is 2 times var#2 )
#4 Post by TD-er » 18 Oct 2023, 01:08
Ah check!
I changed it for future reference :)
It also means it is time for me to turn off my head and put my computer to sleep... or something like that ;)
