I have a sensor with PWM output.
At the moment I am using a ready-made module on an operational amplifier and reading the measured value using ADC.
But are there any modules that would allow reading the pulse width in digital form?
Retrieve the PWN value
Re: Retrieve the PWN value
You mean like [Plugin#GPIO#Pinstate#N] (with N being the GPIO nr) but then for the PWM value as a state?
I just looked at the code and it doesn't work like that, but I guess we could add it as a feature.
Not sure whether it should be called "pinstate" or "pwmstate".
It might work... but processing the function also tries to read the pin state and not sure what this will do to the PWM which is running.
