simple command issues error
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
uxhamby
#1 Post by uxhamby » 20 Nov 2023, 23:14
I have a fairly vanilla RPiEasy system (RPIEasy 2.3.273) running on an older RPi.
Type: RPI-Linux-apt (supported)
OS: linux 6.1.0-rpi4-rpi-v6
OS full name: Raspbian GNU/Linux 12 (bookworm)
Hardware: Pi 1 Model B 512MB
I have set gpio2 and gpio3 to be outputs, via the hardware page and I have rebooted the RPi.
when I issue the simple command 'gpio.2.1' (or gpio,3.1), as I am used to doing on ESPeasy systems, I get error as follows:
False
16:00:19 : Webserver starting at http://192.168.55.151:80
16:01:12 : CMD: gpio,2,1
16:01:12 : Unknown command: gpio,2,1
17:01:15 : CMD: gpio,2,1
17:01:15 : Unknown command: gpio,2,1
Is there some documentation somewhere I should be referring to, to figure out what I am doing wrong?
Thoughts or advice welcome.
Cheers,
Brian H.
Re: simple command issues error
#2 Post by Ath » 20 Nov 2023, 23:24
Have you added and enabled at least one Switch task (P001)? As one of the first comment lines in that source file states that to be able to use the gpio commands, an instance of the plugin has to be available...
uxhamby
#3 Post by uxhamby » 20 Nov 2023, 23:52
I was unaware of that requirement, I will give it a try, Thanks,
Brian H.
uxhamby
#4 Post by uxhamby » 21 Nov 2023, 01:35
Thanks Ath, your suggestion has solved my problem.
Brian H.
