This power socket should be compatible with espeasy AND it should have enough space to DIY build in a SSD1306 Display.
Also the esp inside must be able to drive the display (micro soldering is okay).
The purpose of this project is to fit the socket in between the coffee-maker.
The display should be indicating the time elapsed between a high current detection (which happens when the water is heated, sustaining the coffee heat requires less power).
This way the office-collegues are able to see how old the coffee in the can is.
Who can point me to the right socket-device?
