RFLink over wifi and Home Assistant
bajzel
#1 Post by bajzel » 14 Jan 2024, 18:58
I've bought and successfully run RFLink on Arduino connected via USB to the Home Assistant and it was working fine, seeing my sensors and remotes but as the reception was the issue I have bought and installed RFLink / WIFI adapter and NodeMCU.
I've configured it as described on the https://www.nodo-shop.nl/en/content/10-downloads (Wi-Fi and NodeMCU) and it seems to be working fine as I'm able to connect to it from Home Assistant via the network same way as I was able to do it via USB before.
2024-01-14 18:42:38.297 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2024-01-14 18:42:38.304 DEBUG (MainThread) [rflink.protocol] connected
2024-01-14 18:42:38.304 DEBUG (MainThread) [rflink.protocol] applying TCP KEEPALIVE settings: IDLE=60/INTVL=20/CNT=3
2024-01-14 18:42:38.305 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
The issue is that I to not see any 433 communication being passed on via that and I am a bit lost what am I missing and what is my next step.
Attaching all settings on my ESP Easy.
I feel I have missed some step / am missing something obvious hoping for you help.
Have a great day!
bajzel
Screenshot 2024-01-14 at 18.53.29.png (73.8 KiB) Viewed 17217 times
Screenshot 2024-01-14 at 18.53.54.png (78.3 KiB) Viewed 17217 times
Screenshot 2024-01-14 at 18.54.02.png (27.32 KiB) Viewed 17217 times
Screenshot 2024-01-14 at 18.54.09.png (49.83 KiB) Viewed 17217 times
Screenshot 2024-01-14 at 18.54.22.png (101.57 KiB) Viewed 17217 times
Screenshot 2024-01-14 at 18.53.43.jpg (66.13 KiB) Viewed 17217 times
